Adding "launch" to Indicators line?
How would i add this?
I got the input on JS5. I had it working with MS1-extra, now using MS2extra
I would like a symbol "LAUNCH ON" when launch is activaed with my clutchswitch
Re: Adding "launch" to Indicators line?
I addded this to my ini file for 2.0.1 extra MS2 . You will need to test it out and see if it works and you may need to switch the Launch ON and Launch Off around to make it display correct i have not tried it yet but it does display it at the bottom now.
Since your using JS5 witch is ADC 6 your MT will look at ADC 6 for the activation it may work but im not sure try it and see.
indicator = { ready }, "Not Ready", "Ready", white, black, green, black
indicator = { crank }, "Not Cranking", "Cranking", white, black, red, black
indicator = { startw }, "ASE OFF", "ASE", white, black, red, black
indicator = { warmup }, "WUE OFF", "WUE", white, black, green, black
indicator = { tpsaccaen }, "TPS Accel Enrich", "TPS Accel Enrich", white, black, green, black
indicator = { mapaccaen }, "MAP Accel Enrich", "MAP Accel Enrich", white, black, green, black
indicator = { tpsaccden }, "TPS Decel", "TPS Decel", white, black, green, black
indicator = { mapaccden }, "MAP Decel", "MAP Decel", white, black, green, black
indicator = { adc6 }, "Launch Off", "Launch ON", white, black, red, black < < < < Right HERE
; indicator = { port0 }, "Port 0 Off", "Port 0 On", white, black, red, black
indicator = { status1 & 0b00000100}, "-", "Config Error", white, black, red, black
indicator = { status1 & 0b00000001}, "-", "Need Burn", white, black, red, black
indicator = { status1 & 0b00000010}, "-", "Lost Data", white, black, red, black
indicator = { status1 & 0b00001000}, "Not synced", "Synced", red, black, green, black
Edit: because variable was wrong in ini file.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
thanks you i'll try as soon as i get the oilpan back on the car
best ET 10.71 so far, after lots of MS related problems :S
where can I find a list for the ADC numbers? I use JS11, i tried port6 but it doesn't work (can't remember where i found this). the indicator is there but it stays off. Launch control is working fine tho.
'93 Suzuki Swift 993cc 3 cylinders with a TD04L-13T , melted piston @ 25psi with a bad fuel pump. MS2E 3.0.3 standalone
'07 Suzuki SX4 2.0L , TurbineTech turbo kit. MS2E 2.0 used as a piggyback
The "port" variable only reflects "generic port" OUTPUTS. Consequently it will not show a port output for any other reason and does not monitor inputs.
Is there any way I can configure this indicator if I use JS11?
I dont get this
this line aperantly would show if JS5 is on or off in megatune. In the drawings for the V3 board it shows JS5 is called PTB6/AD6. How is this connected. Same thing with my problem, I have read somewhere that i should have a string with "port6" when conneted to JS0 in megatune but on the drawing it reads PTA7/KBO7 ??
/ Christian
/ Christian
Camaro -68, 327 th200-4r, MS2 extra, autorotor 2,2l
Try out pre2.0.2a - I've already added lots more indicators.
Well just got my indicator line working as I found this table:
port0 = PM2 = Fidle
port1 = PM3 = Injection LED
port2 = PM4 = Accel LED
port3 = PM5 = Warm-up LED
port4 = PT7 = IAC2
port5 = PT6 = IAC1
port6 = PA0 = Knock Enable
I changed the line in the ini file form port6 to port5. Seems port5 = PT6.... Anyway now the indicator line works with the stimulator, will try tomarrow in the car.
port0 = PM2 = Fidle
port4 = PT7 = IAC2
port5 = PT6 = IAC1
