MegaTune p3
v3.57 board
Dell PIII Laptop
Windows XP SP2 (all updates)
9pin serial cable
MegaTune was working perfectly for me until about a day or so ago... now every time the MS unit resets MT locks up. I've tried checking ports (port check says "connected OK"), port settings (all set to what is defined in the MegaTune manual), power management settings (does it in battery mode and on AC), cable connection, re-MSQ, re-flash... nada
complete MT uninstall (including INIs), and reinstall... complete Reflash including boot code. checked and triple checked connection settings... still locks up on every ECU reset.
enabling debug, this is what I find at the end of the log where I turn the ECU back on... its a complete data set, but its like MegaTune doesn't know what to do and freezes
Code: Select all
81775 PURGE
81775 SND A
0001 bytes written
81775 X RCV
81775 ERROR 0x00000000
81875 PURGE
81875 SND A
0001 bytes written
81875 X RCV
81875 ERROR 0x00000000
81980 PURGE
81980 SND A
0001 bytes written
81980 RCV 00 00 0b b8 0b b8 00 00 00 00 00 00 93 93 01 01
03 42 03 42 06 c4 08 14 00 04 00 7b 00 94 00 94
00 00 00 64 00 64 00 53 00 64 00 00 00 64 00 6c
00 64 00 64 00 64 00 a0 00 00 00 28 00 00 00 2f
00 00 03 42 00 64 00 00 00 00 00 fc 00 fc 00 00
00 00 01 21 00 00 00 0a 00 00 03 42 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 c6 00
a5 00 00 00 00 00 00 00 70
