Its MS2 running a VW 2l 16v.
I have the car running perfectly at idle, afr, just a tad rich. But when starting the car using the numbers defaulted in the warm up wizard, it stalls and is REALLY lean.
If I richen it the last number (not 102) is about 115 and gets larger with lower temp.
Is this acceptable?
Warm up info
Warm up info
1981 VW Scirocco w 2L 16v
Re: Warm up info
Ok. What I am asking is, should the car warm up lean or closer to stoich?
If lean it will warm faster, but will it damage the engine?
Re: Warm up info
Bear in mind even a heated Lamda sensor doesn't read well until engine has warmed up
Nige
Nige
on http://www.LR4x4.com (Land Rover forum post under Hybrid_From_Hell)
http://www.megasquirt-v8.co.uk On line webshop for all things V8 .....Particularly V8 Rover and Megasquirty
