Hi guys,
As I will be using me already installed Zeitronix ZT-2 WB with the Megasquirt, I had a look at the Megatune 2.25 and there is just the option of the non-linear wideband output of the ZT-2 and that makes the AFR Target tables to read in Volt. (the newer ZT-2 have a non-linear, as well as a linear output)
As I don't wan't to hassle with the AFR/Volt calculation all the time (and I am used to deal with AFRs from the EMU) I had a look at the background of the lambda sensors in Megasquirt.
There is the lambdaSensors.ini file within the Megatune2.25/mtCfg/ folder. In this file there seem to be all the calculation algorithms for the AFR calculation from the voltages comming from the WBO2.
like for the Innovate 0-5v 10-20:1 AFR
#elif INNOVATE_0_5_LINEAR
afr = { 10 + egoADC * 0.039216 }
lambda = { afr / 14.7 }
TargetAFR = { 10 + afrtarget * 0.039216 }
TargetLambda = { TargetAFR / 14.7 }
Would it be possible to change this ini-file to match the ZT-2 linear output?
Zeitronix descibes the function for the AFR at the linear output as follows:
"The Linear Wideband Output transfer function is AFR=2xV+9.6"
This is were my knowledge at this point ends - I don't know what the string egoADC means, it is not the sensor voltage - because otherwise it wouldn't fit the AFRs.
Just a thought to make the life for the ZT-2 user a bit easier. Any ideas?
O.K. found some more new background (at least for me, I suppose the pro's already know this...)
In a thread at your board:
Q:
I was looking at the formula in lambdasensors.ini and for the LM-1, the formula is: 10 + egoADC * 0.039216. I'm confused on what the 0.039216 value is for because it doesn't look like [O2] * 2 + 10 to me.
A:
The difference is one is working against O2 volts (0-5) the other is ADC (0-255)
ADC 0 = 0V
ADC 255 = 5V
so:
5/255 = 0.01960784313
so:
2*0.01960784313 = 0.03921568627
Therefore:
and
10 + O2volts * 2
are the same
So in the case of the ZT-2 it would be:
afr = { 9.6 + egoADC * 0.039216 }
TargetAFR = { 9.6 + afrtarget * 0.039216 }
Right? Wrong?
I appreciate any help.
Thanks!
__________________
Greetings from Germany
Changing lambdaSensors.ini for Zeitronix WB ?
fun is not a straight line
Sven
Sven
Re: Changing lambdaSensors.ini for Zeitronix WB ?
Looks like you got it right.
thanks for the reply -
I suppose, I do also have to change the msns-extra.ini in my cars project folder?
afrBins1 = array, U08, 0, [8x8], "AFR", 0.0392, 255.0, 10.0, 20.0, 1
to
afrBins1 = array, U08, 0, [8x8], "AFR", 0.0392, 255.0, 9.6, 19.6, 1
Is this also correct?
Thanks!
to
Thanks!
Sven
Sven
Good catch, that would fix your mins and max's, but then you also need to tweak your translate so it starts at 9.6:1 on display. so:
On the innovate the translate would add 255 to the byte value, then multiply by the scaler (0.0392), so a true byte value of 0 would be 10 in your display. Changing that to 244.8 will make a true byte of 0 = 9.6:1 in your display.
Code: Select all
afrBins1 = array, U08, 0, [8x8], "AFR", 0.0392, 244.8, 9.6, 19.6, 1
Thanks again for that!
Sven
Sven
