I just recently upgraded from 029v to 029y4 extra cord, I've noticed that the datalog file sizes are much smaller.. They used to be 400-700kb, when now, similar time frames are only 150-200kb. Is this normal? I have the bitrate set at 9600 and the right com port, etc.
I'm running ms1 v3.0 with edis.
Megatune datalog file sizes
81 931
-ms1 v3 w/edis
"It's not cobbled, its CUSTOM!"
-ms1 v3 w/edis
Re: Megatune datalog file sizes
No, that isn't normal. With the same MegaTune settings, the records per second should be pretty much the same.
There are a couple minor changes to the logged fields 1 added / 1 deleted so that should balance out more or less.
Are you getting rough;y the same number of rec/sec?
What is Time interval set to in the Communications Menu?
9600 and 50 for the interval.
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
What is the record per second count?
To check, look at the Time field count how many records you see before the second rolls.
How do I change the record per second count higher?
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
In the Communication Settings dialog, lower the interval. The best you will get from MS1-Extra is about 17-18 records per second using a serial cable. Other connection types may be lower.
