I will probaly get wrapped on the knuckles for this, because it has most probably come up a while ago...
But is there any shortcut to switch between Fuel Tables and Spark Tables (2D & 3D) while tuning.
Cause having to close one window in a rush then try and open another to do a quick change and then have close that on and re-open the window you were originaly busy with, Back and Forth all the time is a bit of a pain....
Had a look to see if there was anything , but couldn't find anything.
Using MT2.25
Once again thanx for the Help Guys......
Regards
Andrew
shortrtcut to change between VE Table and Spark Tables?
Re: shortrtcut to change between VE Table and Spark Tables?
This could possibly work in MS2 BG, but will not work in MS1/Extra or MS2/Extra as they use a paged memory arrangement. You HAVE to burn before you leave the table as a result. With MS2 BG (and MS3) you don't need to burn immediately because both (all) data pages are concurrrently held in RAM.
So, aside from the existing technical limitations of the firmware it is a good idea. So good, that I think Dave A has already included it in Megatunix !
