Dear All
Yes,I am stupid,but how do you create a new VE map for fuel,have found the tool that is supposed to do it in the MS manual,(entered all the figures) but I don't get a pop-up,
Have looked under tools (as in the MSextra manual ) and all I have is Table editor,Dump and review,the best I have got is in the table editor putting the dot in the DEC radio button....
John
Ms extra o29y3
Map Creation
- Running MSx/Extra
Re: Map Creation
Bring up the VE table.
On the table there is a Tools menu from there go to VE specific > Generate Table
- Running MSx/Extra
Re: Map Creation
Werner
Many thanks,getting late now,will give it a try in the morning..
John
John
- Running MSx/Extra
Re: Map Creation
Werner
You were right,silly me looking under tools on the main screen,it's under tools on the VE screen,so have made the map and given it a try,seems as though the figures are double what I need,have had to half my Req Fuel to get the mixture anything like Lambda at warm tickover ....this can't be anything to do with No. of squirts or alternating can it?
Have re-calculated my req fuel and it comes out at 14.4 but with these generated numbers lambda at tickover requires a Req Fuel of approx 8....
Where have I gone wrong??
John
John
Re: Map Creation
John, the numbers are all relative; all that matters is the final fueling calc result. You actually want larger numbers in your VE table as this will give you more granularity and allow you to adjust the fueling in smaller steps. Also, very few engines like stoich at tickover - most want to be a bit rich.
- Running MSx/Extra
Re: Map Creation
Mike
Yes,I realise that, but it seems my fuel map/Req Fuel figure is giving me mixtures twice as rich as they should be (enrichments turned off-revving slowly over a limited range).....but at least it starts better and have no problems with the ASE and Warmup...
John
John
