Clt rev limiter settings?
Would somebody be kind enough to explain the settings of this?
With the above setting I made it to 9000rpm
Randy
Re: Clt rev limiter settings?
Your "Rev Limit Adder (RPM)" is set incorrectly. The curve specifies the soft cut limit, and RLA specifies the added rpms from soft cut to hard cut. You will probably want to set it to 500 or so. In that case, with the coolant at 68F and the respective soft cut at 2000 rpms, the hard cut would be at 2500 rpms.
When you set RLA to 8100 rpms and with the soft cut at 68F still set to 2000 rpms, the hard cut will be 8100 rpms higher ie. at 10100 rpms, probably more than anyone would ask for.
The entry should probably be renamed to make it easier to understand.
karlo wrote:Your "Rev Limit Adder (RPM)" is set incorrectly. The curve specifies the soft cut limit, and RLA specifies the added rpms from soft cut to hard cut. You will probably want to set it to 500 or so. In that case, with the coolant at 68F and the respective soft cut at 2000 rpms, the hard cut would be at 2500 rpms.
Thanks, I set the RLA to 0 and it is working perfect now. Is kinda weird wording, especially when you have no clue as what it is suppose to do. lol
