I'm not sure what to call it but when I open my MegaTune (2.25 with any of the codes I tried it with) it will show the message to go offline or not, then show the opening screen with the gauges and the C4 vette, then nothing.... but it's in the task bar
after this it's like it minimizes and wont show MegaTune no matter what.
However, if instead of my project HRC I choose car1 (which hasnt been configured) it will open Mega Tune just like normal.
This happened all of a sudden, I was out tuning saved the file, went to open it when I got home and nothing worked.
Has anyone had this problem and know a fix?
MT not opening
Re: MT not opening
give tunerstudio a try?
Never seen this issue personally
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
Re: MT not opening
seems to be good since I uninstalled and reinstalled with the new HRC11c1
Re: MT not opening
I've seen this happen when MegaTune was accidentally set up in one of its config files to open at coordinates that put it off the screen, too. When that happens, you can maximize it and have it appear; this makes a good quick test to see if this is the problem.
