Hi Guys!
I`ve been reading and reading about configuring MS-II V3 and now Im just a little confused about how to set up the Engine Speed, Throttle Position, Pulse Width 1, Exhaust Gas Oxigen Gauges im working on the 2.89 code version ... those gauges seems to be off, only i could turned on the engine map, X-tau Correction1, Ignition Advance and the Dwell gauges and their readings look right...Id like to somebody could help on this task. Thanks!
Setting Up Gauges
Re: Setting Up Gauges
Ey guys i dont know what happened but the gauges are working fine ... I just reloaded the monitor code and it seems to work cool...
