Sorry, searched and couldnt find any info on codes 3, 9 & 13, and was not sure if this is something in MegaTune code or MS code?
Please advise me If this is in MS code?
Thanks,
bob
What are Engine Bit Codes 3, 9 & 13?
88 turbocoupe: ms-II v3.0 - running MS2X 2.0.1
Holset HX35W saying "wheres my cummins at???"
forget diesel, who says stock gas motors cant run 30+ psi?
Re: What are Engine Bit Codes 3, 9 & 13?
i did find a bunch of the codes in megasquirt-ii.ini, but no 9 or 13
it lists this in the ini:
Squirt Event Scheduling Variables - bit fields for "squirt" variable above
; inj1: equ 3 ; 0 = no squirt 1 = squirt
; inj2: equ 5 ; 0 = no squirt 1 = squirt
; sched1: equ 2 ; 0 = nothing scheduled 1 = scheduled to squirt
; firing1: equ 0 ; 0 = not squirting 1 = squirting
; sched2: equ 4
; firing2: equ 1
so how does this work, engine code throw a 3 if inj1 returns 0 or 1, or does only one of those values throw a 3...
; sched2: equ 4
; firing2: equ 1
Engine is a bunch of bit fields:
So if you look at the bits in 3, 9 & 13:
3 = 00000011 = Running + Cranking
9 = 00001001 = Running + Warmup
13 = 00001101 = Running + Warmup + ASE
The engine field is what drives the display in MLV, so you don't really need to break it down like that, MLV does it for you.
Code: Select all
running:equ 0 ; 0 = engine not running 1 = running
crank: equ 1 ; 0 = engine not cranking 1 = engine cranking
ASE: equ 2 ; 0 = not in after start enrichment 1 = in after start enrichment
warmup: equ 3 ; 0 = not in warmup 1 = in warmup
tpsaen: equ 4 ; 0 = not in TPS acceleration mode 1 = TPS acceleration mode
tpsden: equ 5 ; 0 = not in deacceleration mode 1 = in deacceleration mode
mapaen: equ 6 ; 0 = not in MAP acceleration mode 1 = MAP deaceeleration mode
idleOn: equ 7 ;
