I had been using a system similar to MEgatune for a while on my old ECu setup, and just recently switched over to a real Megasquirt. And i'm running ms2 extra 1.0.2.
When i was using the older version of megatune i got used to seeing KPAs and RPMs on my VE table, now i see % and RPM. I tried looking through the manuals and seeing if there was an option to change that...
what do the % stand for? % of what?
Ve Table question
Ve Table question
1986 Mitsubishi Starion MPI 17c@18psi
Ms2 v3.0 MSx 1.0.2 Direct Coil Control
((Not Currently Running))
Re: Ve Table question
% of 100kPa.
The change was made so that one symbol could apply to %TPS, %baro or %kPa.
So, the numbers are the same, it just says % intead of kPa.
ooooh okay. so thats why when i load mine up for the first time its sitting ar 100%, aka 1 atmosphere. perfect! thanks!
