hello
how to use afr table to set value 7 , minimum value seting at 9 , i use E85 fuel ?
ms1 v3 or ms2 v3 last code
thanks
how to set this
how to set this
citroen bx 8 valves xu7te home made
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
Re: how to set this
Just simple use the AFRs you used for gasoline.The LC-1 will never show anithing under 7,4 AFR,but it should not.It sees Lambda,and multiplies it with 14,7.So if you see 14,7 with E85,it is really about 9:1,wich is lambda 1 on E85 (im not sure on 9:1 )
Audi A8 1.8T AEB, Paralel ecu for A/C,MS2 V3 on 2.1.0 Code,Boost,launch,Fuel&spark,etc..
Fiat X1/9 1.6 turbo MS2 extra V3
Hungary,Lake Balaton
