Ok, so car is all wired up. Coils are left unplugged. I have a trickle charge keeping the battery going. Currently at 14.5-15v
Pc: windows 7 , using aten usb to serial bridge. Latest driver. (works fine on my msd dis-2)
MS info: 2.1.0 build 20090627 kc/jsm***ms2
I have the latest software package on diyautotune's sight.
I can do port check all day long, half the time its there on com1 half the time its not.
I did however get connected once on tunerstudio, on the autodetect..but by the time I made it to port check it wasn't working again. I've been going back and forth on this and am pulling my hair out.
I can't connect in megatune at all, port fails.
Anyone have any advice?
I've updated everything I can, restarted the pc. Turned car on/off. I can unplug usb and replug and sometimes it comes back. I'm sorry if I have missed something, or not included enough info. I've went through the manuals over and over and followed every instruction I can find.
Cant connect for the life of me
Re: Cant connect for the life of me
about an hour after this post I swapped to com6, everything started working fine. Not sure what the deal is with com1. I think its a windows 7 thing.
com one is typically a built in serial connector so won't use that for a usb adaptor.
on the sytem menu in control panel, if you go to hardware devices and select the appropriate com port it'll tell which it's working from and what settings.
you can alter the com port in the settings, but best to let it choose its own.
