when i start megatune i get this
expected:msns-extra format 027c---------found in .ini file
received :ms1extra format 029y3--------from controller
table corruption may occur
terminate megatune now?
i trying to set up for ms1 on a v3 board and run it on the 029y4 platform
8i need a fix as fast as possible
megatune error
Re: megatune error
replace the msns-extra.ini in the megatune install with the one that came with your firmware. Or install TunerStudio, it has the current ini file and should detect it for you.
