Hello,
I have a vw rabbit convertible with 1.8 16V conversion. I installed a MS2Extra and I am now at the point where I want to enter the initial settings and base maps to get it running for the first time. As far as I could check, my temp sensors, TPS and crank trigger seem ok, but I can't seem to get any spark output from the MS. I have a VW 032 905 106 DIS coil pack with built-in ignitors which will run in wasted spark mode. Too bad I can't seem to figure out how to properly set up Megatune in order to make it spark. Is there anyone who has a similar configuration and/or someone who can help me out please,
Thanks a lot!
How to drive a VW DIS Coil pack
Re: How to drive a VW DIS Coil pack
Post this under MS1/Extra Support
