set up using cam driven 36-1
Questions specific to Megatune. (Only about the tuning software, not about MS1/MS2 code or code features)
Note that Megatune is obsolete.
Postby MORK63UK » Sat Aug 21, 2010 9:29 am
Hello,
I'm looking at setting up my 1986 Citroen CX GTI turbo to run on megasquirt. sorry if I sound like a 16 year old newbe 'more a 47 year old' I would like to know if it is possible to trigger the unit from the camshaft using a 36-1 trigger wheel. I'd prefer not to take the engine out again... there's no crank pulley on these engines so it would mean having the flywheel drilled to a 60-2
currently the engine runs 2 sets of std injectors 'basically two injection sets' but I was looking to refine the engine management.
I have the trigger wheel all ready in place and really looking for re assuance it should work... and how to go about it please.
MORK63UK
Re: set up using cam driven 36-1
Postby Matt Cramer » Mon Aug 23, 2010 1:39 pm
Sure, this isn't too hard to do - what firmware are you running?
Postby MORK63UK » Mon Aug 27, 2012 4:20 am
Well where did those two years go? I have 3.2.1 firmware and the cam trigger in place now.
This is still new to me and I have only connected it to the car to test if the signal from the trigger is working... there is a signal but in latest version of TS it only shows half the rpm the engine is running at.
I have the project set up to run cam driven toothed wheel 36-1 and wasted spark as my intention, was to run this through the MSD ignition already on the car.
Is there something else I'm missing please?
cheers
MORK63UK
Postby Matt Cramer » Mon Aug 27, 2012 6:12 am
Could you post a copy of your MSQ? I'd like to check the settings first.
Postby MORK63UK » Sun Sep 09, 2012 11:57 pm
attached the file thanks, this is my first attempt
MORK63UK
Postby Matt Cramer » Mon Sep 10, 2012 6:29 am
Sorry, looks like the file didn't attach correctly.
Postby Trump » Mon Sep 10, 2012 11:25 pm
Just a thought, what speed did you set the trigger wheel in TS (Ignition Options Wheel/Decoder). As your wheel is driven from the cam, if you set it at "çrank" then it would show at 1/2 crank speed. Set it to Cam.
Sydney Australia
Triumph TR3A. MS3X, Fully Sequential Injection, Wasted spark, 60-2 crank wheel.
Trump
Postby MORK63UK » Sat May 18, 2013 7:11 am
sorted the signals out, it all works fine now after downloading the latest firmware... this is a long project :)
MORK63UK
Return to Megatune (obsolete)
