I'm currently in the process of tuning the Fuel VE Table. I'm tuning live with the engine on, and I use the 3-D Fuel VE Map to tune. The problem is I can't swap the default dials that show in the Fuel VE Map. I need to swap in the Coolant Temp Dial in order to monitor engine temp while tuning the 3-D Fuel VE Map. How can I do this? Please help!!!
Thanks,
-A. Calvo
Fusion Motors, Turabo Formula SAE
2003 Honda CBR600 RR engine, four-stroke, 600cc, i-4
MSII Extra v 3.0, 2.1.0d firmware,
Wasted Spark, MAP based
MegaTune 2.5
Single Throttle Intake manifold w/ 20mm intake air restrictor
Coolant Temp Dial in Fuel VE Map??
-A. Calvo
2003 Honda CBR600 RR engine, 4-stroke, 600cc, i-4, Naturally Aspirated
MSII Extra v3.0, 2.1.0d
Wasted Spark, Speed Density
MegaTune 2.25 p3
"Nothing that's worth it is ever easy"
MegaTune 2.25 p3
Re: Coolant Temp Dial in Fuel VE Map??
You need to open you associated Megatune *.ini file, then go to near the bottom for the gauge configurations. There's a numbered listing of the gauges as they appear, and you just need to edit one of them to the proper gauge label. For example, to switch the Accel Enrich gauge for Coolant on the EGO 'page', locate the following in the *.ini:
; Page 1 Page 2 Page 3 Page 4
[other gauge information here]
gauge6 = accelEnrichGauge, accelEnrichGauge, dutyCycle1Gauge, dutyCycle2Gauge
and swap 'accelEnrichGauge' under the Page 1 column for cltGauge (all gauges are defined above that coding in the *.ini file).
Alternatively, TunerStudio is java based and you can customize your dashboard (if registered - well worth it!) to use any gauge in a multiple of forms, without editing files.
Justin
**EDIT** Wow, just saw the date... my bad!
Justin
'95 Eclipse 420a
MS2-Extra Fuel & Spark
t3/t4b 16psi
t3/t4b 16psi
