- MsII & v3.0
- Winxp
- Hardware serial port
- All drivers etc up to date
Hi, I've found one thingy from Megatune programmable output window. Everything what I've tested works okay until I select an seconds for a variant. Then it goes bad. I can put anything to amount and hysterisis etc and burn them up. But when I want to come back, megatune has lost this output setting. I shows only wb for a variable and all values are zero. Looks like it sends commands right to the cpu, coz tunerstudio reads it out right. It does not affect all prog output settings, just this one. I haven't tested other variables than coolant and seconds.
Megatune programmable output nag.
Volvo 244 gle, b19e msns. R.I.P.
Vauxhall Viva, Msns. "Finally working"
Volvo 945 Turbo -97, Ms II. "There can't be more resistant install than this"
Re: Megatune programmable output nag.
i can confirm this bug, happened to me when i've hooked an auxiliary air valve to control idle speed when engine is cold, tried to make it time based in MT but everytime i burned the values, after a MT restart the output port values were lost, thus in TunerStudio all works ok.
