error when trying to connect
Questions specific to Megatune. (Only about the tuning software, not about MS1/MS2 code or code features)
Note that Megatune is obsolete.
why
Post by why »
alright so straight to the point, when trying to connect to ms2 i'm getting an error code
controller code version doesn't match
expected ms2 rev 2.88600
received ms2 extra rel 2.0.0
what can cause this? and what can i do to remedy this problem, thanks in advance
Re: error when trying to connect
If you wish to stick with Megatune then you need to install the ini file that matches the firmware.
However, if you use TunerStudio instead, it will do it automatically for you.
If this is a new install, you should also consider using the current firmware on your Megasquirt.
See: http://www.msextra.com/doc/index.html#ms2
