Hi All
I using megatune 2.25 p3 with my MS1 extra, on a motorcycle. Alt-L keys work to turn logging "on". Is there a hot key to turn datalogging "off"? Is there a list of Hot keys somewhere?
Hot key for datalogging "off"?
Re: Hot key for datalogging "off"?
Control B datalogs off.
Thanks for the quick reply. Working on datalogging right now, will try Ctrl B.
Well, you say you use ALT L, and I use Control L. So not sure if different keyboard layouts (Portuguese here) will set different keys to be used (ALT and Control) but if not Control, maybe ALT B, I guess.
With _Megatune_ ?HidRo wrote:Well, you say you use ALT L, and I use Control L. So not sure if different keyboard layouts (Portuguese here) will set different keys to be used (ALT and Control) but if not Control, maybe ALT B, I guess.
TunerStudio uses different keys.
Hi All
The ctrl-B keys did not work for me, but did lead me to tring other Hot Keys. Thanks for the Help and reply.
I am not sure of the following Hot Key use, but it has worked for me. I am using Megatune.
A. When I want Megatune to start a datalog.
1. To open a new datalog file I use Alt-L keys, to call up the log menu.
2. To start the new datalog I use Alt-S keys.
B. When I want to stop the datalog: use Alt-L then Esc Keys. (correct)
(EDIT: The following was incorrect, so I deleted it.)
I there a list of Megatune Hot Keys?
In Megatune I used ALT-L to start a log and then ALT-L, ESC to stop a log.
Hi James
Thanks for the reply. I was wrong about my Hot Key use to stop the logging. Is there a list of Hot Keys somewhere?
