Error accessing audit log
Note that Megatune is obsolete.
MG David
Post by MG David »
(MS1 v2.2, Megatune 2.25 p3, only being used for ignition and data logging)
After loading the 029y4 firmware for the first time after assembling my MS I openned the file I had been setting up ready.
I had a warning to check the audit log before writing my settings to the Megasquirt
As I didn't know where to find the audit log I went to "help" on the menu bar and the 4th item down was "audit log "
When selected I got he following:
Execute Plug-in
Couldn't edit C:/Program Files/MegaSquirt/Car1/audit.log
ShellExecute error code 31.
OK
Audit log is also the 6th item down and theat returns the same error message.
Any ideas what to do.
Re: Error accessing audit log
Post by LT401Vette »
If you are on Windows 7 or Vista, programs don't normally have write access to files under Program Files. MegaTune isn't compliant with this, so you will need to set the program to "Run As Administrator", then it should be able to write to the files under Program Files
