Hi.
I am oldfashioned and run MS1Extra EDIS and use MT 2.25p1 for tuning and access. MSLVV for analysis and I have recently started to use Autotune, which works great.
Being a stickler for preserving resolution I use the 4115 MAP Sensor ( scrounged from junk yards) since the cars we use are strictly Ford V8 na in the 302 to 427 range. ( replicas of hotties such as AC Cobra, GT 40 and to top it off also a REAL 72 Pantera, which we restore and that will soon ( kind of!!) be back on the road after 10 years of much misuse, abuse and vandalization)
All works GREAT, but I would very much like to change the MT 2.25p1 gauge from reading up to 250 kPa absolute on 270 degrees sweep to 115 kPa on 270 degrees sweep. I have done it earlier but the PC it was on is toast.
Can somebody please help, thanks.
In the MT file I have pasted in the kPa 4115 file and also set 4115 , unset 4250 so all is working as it should , but would be nice with a 270 degrees sweep.
W113
Help change MAP display range
If not understood , it will not work
Re: Help change MAP display range
The original gauge definition would have been.
mapGauge = map, "Engine MAP", "kPa", 0, 255, 0, 20, 200, 245, 1, 0
Now it should be.
mapGauge = map, "Engine MAP", "kPa", 0, 115, 0, 20, 105, 110, 1, 0
Now it should be.
Hi, and thanks a lot. I had an inkling it was like that, but in which file should I change that.
MtCommon, MtCfg, Car1??
Any help welcome!
Thanks, again,
Ola
Any help welcome!
Thanks, again,
Ola
Been a while since I worked with MegaTune, but...
If you have it set to MSNS_EXTRA, it will be looking for an ini file named MSnS-extra.ini
If you only have the one project "Car1"
it will pick the one that it uses by 1st looking in the dir:
Car1/mtCfg/
If there isn't a MSnS-extra.ini there is will use the one in:
MegaTune2.25\mtCfg\
Car1/mtCfg/
MegaTune2.25\mtCfg\
Thanks a lot , now I get it. And have made the change, all works exactly as stated.
Happy as a clam, 270 degrees sweep on 115 kPa!
Great
W113
Great
W113
