problems turning off over run fuel cut
Questions specific to Megatune. (Only about the tuning software, not about MS1/MS2 code or code features)
Note that Megatune is obsolete.
Postby alfanatiker » Fri May 29, 2015 2:17 am
I just started using my MS3X last Sunday, and yesterday I started with the autotune function. But I can't get off the over run fuel cut. It looks like it's of, but still my lambda shows 22,4 on overrun above 2000rpm and kpa lower than 35 (the numbers I put in there). This makes the autotune to increase the VE to stupid high on my lower points on the fuel table. 3100rpm and 40-30kpa for instance now getting up to 90% VE...
alfanatiker
Re: problems turning off over run fuel cut
Postby Matt Cramer » Fri May 29, 2015 5:46 am
:msq:
Postby LT401Vette » Fri May 29, 2015 6:12 am
Are you actually using TunerStudio, not MegaTune? (I assume so as MegaTune doesn't support MS3)
LT401Vette
Postby alfanatiker » Fri May 29, 2015 9:11 am
Sorry. Of course I´m using tunerstudio. I´ve started the same topic on the right place. Also I included a msq-file from the current tune.
viewtopic.php?f=122&t=58892
alfanatiker
Return to Megatune (obsolete)
