Alternative EDIS-6 coil pack… pics.
While tromping around the U-pull-it yard, I noted that some of the Chrysler Min-vans and Dodge Intrepids/Eagle Vision, were utilizing a 6 cylinder coil pack similar to the Ford EDIS coil packs but with GM HEI style high tension lugs. The more I thought about this asn the more I searched for NICE wires for the Ford coil packs, the more I realized that finding nice wires for the Ford coil packs is pretty difficult, but if these Chrysler coil packs will work and I can just use a GM HEI style boot , then I could save $$.$$ on wires and have the option of pretty much any wire manufacture I choose, i.e. Magnacor. Coil packs are only $25 at my U-pull-it yard, so if it doesn’t work out for what ever reason, not that big of a loss.
Primary resistance of the Ford coil packs was measured at .7-.9 ohm on my Fluke 87, (no idea why the range other than maybe the connector on the coil pack?). The Chrysler coil pack measured .7 ohms on all three coils, so electrically, it should work.
Also worthy of note is the back side of the Chrysler coil pack is FLAT, which makes mounting it in various locations that much easier than the Ford. When mounting the Ford Coil packs, try utilizing the OE mounting bracket the coil was mounted on in its donor vehicle, this will help tremendously. The Chrysler pack makes it even that much easier.
EDIS 4 and EDIS coil pcaks....
EDIS-4 coil alternatives. From what I understand there is an alternative coil pack for the EDIS-4, the Dodge Neon coil pack are supposed to work with EDIS-4, (that is what gave me the idea to look for the Chrysler 6 cylinder coil packs), and the Neon Coil pack has the plug towers out the side of the coil pack which, for some installations, will allow for a cleaner plug wire routing. Also, the bottom of the Neon coil pack is flat which makes mounting it a bit easier than the EDIS-4 coil packs. The Neon coils should also work on the EDIS-8 system as well.
I just happen to have a Neon Coil pack in my shop that is going on my friends Datsun 510 MSnS-E powered L-20-B four-holer, (his wife’s car. Plan is to get this to work on the Dime first, then his E-30 BMW M-3 might get it’s own MSnS-E…)
I don’t see any reason whey you couldn’t use ANY coil that has dual posts on it for EDIS systems, i.e. 2 of the GM wasted spark coils for a 4 cylinder, 3 for the 6 cylinder, and 4 for the 8 cylinder.
Hmmm.. Why couldn’t someone use and EDIS-8 system for fire Coil On Plug four cylinder? Hmmm..
Any how, here are some pics I just took of that Neon Coil pack next to one of my EDIS-8 coil packs, (same as the EDIS-4).
How's the retention of the coil wires on the GM style coil packs? EDIS equipping a Subaru - and that Neon coil pack looks near ideal, matching the opposed H-4 cylinder layout. Just wondering how well the coil wires will stay on? I'll have to pop the hood on the family Caravan and see how that one is set-up!
Jeff
Jeff
thats cool see alterntives to edis coil packs, when useing EDIS on my briggs stratton 3.5 motor . i used a single coil over plug frm a honda, never measured the resistance (probley should checked before useing it) but it worked fine i got that motor to tach out at 7k! !! i never seen a briggs do that before sucker got really hot exhaust was glowing hehehe..... i like idea of useing different pack because ive already melted 3 sets of 40 doller bosch EDIS wires (frm ford escort) becaue dam coil pack is a good distance away from the plugs, and wires are next to the orange glowing manifold
Sean.....
Sean.....
Im hear to take over everyone and there megasquirt, ive been there done that with my own EFI gizzmo's check my site out for more!!
Coil packs and Briggs...
You might look at the GM LS-1 style coil packs. They are a single high tension lug terminal and may be equivalent in primary resistance to the Ford stuff. If that is true, it should work fine for your Briggs.Heck, for that matter, pretty much y any generic regular coil that has similar primary resistance should work, I'd think...
FWIW, I used to have an Uncle Franks Blue Wazoom. I had it broke in on Uncle Franks dyno. My dyno sheet showed 13.01 HP from a 5 hp Briggs Rototiller engine. It wasn’t stock of course as it ran on Methanol, (high maintenance), had a hot rod carb, Dyno cams rod, Wiseco forged piston, Comp cams dual valve springs, big cam, etc. Man did that little engine make some torque. Driving around the autocross course, the firing pulses would THUMP your chest HARD!!!! Would’ve loved to inject it with MS and AV gas..
The Blue Wazoom as installed on my SOLO-II Kart.
Yours truly coming across the finish line at opposite lock.. YEE HAAA….
ohh yeah ! i can top that off hehe check this out!!!
www.motorsportwerke.com/e30turbo/turbo1.avi
www.motorsportwerke.com/e30turbo/efi1.mpg
the avi is in divix so u need the codec and the mpg is normal mpeg...
the turbo motor was my first attempt to EFI and understand what heck it was (i was 19 at time out high school ) i used a parallax basic stamp tp inject the fuel ( very crude way of doing it) i had that motor doing 4 psi of boost!!! even tho there was no load on engine and my rev limiter was kicking in most time u can hear the turbo spooling
the second video is something i did in summer, its a 3.5 with my newly designed EFI controller i tried building had a nice interface it was directed towards gokart motors and used the EDIS , worked great just had I2C problems between the controller and interface sorta gave up on it because of my turbo bimmer project ....
top that if yeah can buddy
Sean...
Sean...
Re: EDIS 4 and EDIS coil pcaks....
Paul,BRAAPZ wrote:Hmmm.. Why couldn’t someone use and EDIS-8 system for fire Coil On Plug four cylinder? Hmmm..
Because it fires every 90 degrees, not every 180... You'd need to put the trigger wheel on the cam to get the four outputs to be at 180 d intervals for a 4-cylinder, and then you'd lose a bunch of timing precision due to the timing drive slop. Dave Hartnell has an I3 running COP using EDIS-6, I don't recall the details, but he might be firing the plugs on the exhaust stroke, too.
Eric
Right you are, Eric. Guess we'd need a pair of EDIS2 setups, huh?BRAAPZ wrote: Hmmm.. Why couldn’t someone use and EDIS-8 system for fire Coil On Plug four cylinder? Hmmm..
Wrecking yard is your best bet.milosch01 wrote:I have one of these chrysler coil packs which I bought new. Any idea where I can get the connector for it? I am guessing I will have to go to the junkyard unless one of you or the dealer has it. It looks just like the one in the pictures at the top of this thread.
Chrysler coil pack pin out...
Here is the pin out of the Chrysler 6 cylinder coil pack. Wires in the harness are “Green w/brown/red stripe”, the triggers are “Black”, “Red” and “White”. I painted the corresponding trigger wire color on the side of each coil in the pack for a quick visual reference when it comes time to wire it up to the EDIS module. I tested this and one other Chrysler coil on the test bench and they pinned out the same.
Hope this helps
Hope this helps
If you already have this coil pack and a pig tail for it in hand, then just looking at this picture should be very self explanatory as far as the pint out is concerned. But I’ll elaborate in text form as well for those that are more audible vs kinesthetic and visual.
The plug is square in shape and has only 4 wires. In the picture above, you are looking at the plug side of the coil pack itself. Now take your coil pack and set it down in-front of you on the table, with the high tension terminals facing up. Now orientate the coil pack on the table in such a manner so that the connector plug on the side of the coil pack is facing your belly, (between you and the coil pack). Remember to keep the high tension terminals facing up and the connector plug facing you. Now make sure your pig tail connector is orientated correctly and plugged in. There is a lock tab on one side of the pig tail connector which coincides with the little tab on the coil pack. Now, looking down on the coil pack with the pigtail plugged into your Chrysler 6 cylinder coil pack, lets move clockwise around this 4 wire connector starting with the upper right wire. The upper right wire is the green wire and is the power wire, connects to #8 on the EDIS-6 connector pictured below. Next then would be the lower right wire which is the white wire and it is the trigger for the coil on the right side of the coil pack in this position. The next wire going clockwise, the lower left wire is the black wire and it is the trigger for the middle coil. The upper left wire is the Red wire and it is the trigger wire for the left coil.
Now in regards to hooking this coil pack up to your EDIS-6 module, depending on your particular engines firing order, (most inline 6 cylinder firing orders are 1-5-3-6-2-4. Wasted spark ignition systems pair up the cylinders as follows for this firing order… 1-6 are paired, 2-5 are paired and 3-4 are paired), all you need to know is the EDIS-6 firing order coming out of the module itself. The firing order coming out of the EDIS module (by module pins in the picture below of the EDIS system) is 10-12-11. This info was found on this forum and also confirmed on our EDIS test bench.
Now with the detailed description and picture of the Chrysler coil pack pin out, the EDIS wiring diagram and EDIS coil firing order detailed and pictured below, you should be set.
SO NOW, if you know your particular engines firing order, I have armed you with enough information here to be able to connect an EDIS-6 using a Chrysler coil pack to your 6 cylinder engine and have it wired up correctly the first time.
There are at least two different connectors for the 4-cyl type. I picked-up two packs and connectors for a waste-spark V8 project and found they were different when I got home. This is now a good feature for me as the packs are close together and the different plugs keep the firing order correctmilosch01 wrote:I have one of these chrysler coil packs which I bought new. Any idea where I can get the connector for it? I am guessing I will have to go to the junkyard unless one of you or the dealer has it. It looks just like the one in the pictures at the top of this thread.
Does anyone know the pinout of the 4 cyl neon packs? I picked up a couple today (both connector types) to try out. If you do know, could you also include a picture of which connector you have incase the two types are different.
EDIT: I took a few pictures you can save then modify and repost if you want. I also took a picture of a 6 cyl pack and wrote on it to help clarify the pinout. If it's wrong please let me know and i'll change it.
Since EDIS-4 fires two coils at once (two coils in series on the secondary), couldn't one fire two COP's on the primary side at once?efahl wrote:Paul,BRAAPZ wrote:Hmmm.. Why couldn’t someone use and EDIS-8 system for fire Coil On Plug four cylinder? Hmmm..
Eric
Example - firing order 1-4-3-2
So fire coil 1 and 3, then 4 - 2....???
