Ford Mustang IAC wiring question
Click here to enter
Contact a Forum Administrator
JUICEDSE
Post by JUICEDSE »
I ordered the PWM IAC control mod kit from DIYAutotune and need some clarification on the diode wiring for "fly-back" purposes.
Its worded as needing to be wired across the valve, is my illustration correct?
1993 Mustang LX 5.0
MSnS MS1 V3.0 029V
Yes, that's how to wire it up.
panel
Post by panel »
What kind of PWM IAC control mod kit do you need to run the Ford IAC valve :?:
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
I believe he's talking about our MK-PWMIAC.
panel
Post by panel »
Matt Cramer wrote:I believe he's talking about our MK-PWMIAC.
Ok I've done that part about the TIP 122 but do I also need to add the DIODE in there :?: Isn't there one already on the PCB for that :?: It doesn't say anything like that I don't think in here http://www.msextra.com/manuals/MS_Extra ... .htm#Fidle
The diode works best in the harness itself.
