Setting up an initial ignition timing table
Click here to enter
Contact a Forum Administrator
Postby rabiddeity » Tue Jun 12, 2007 9:08 pm
What's with the magical 3000 RPM number? Wouldn't that change between engines that redline at 5000 and those that redline at 8500 (small inline 4 engines) or even 14000 and up (like motorcycles)? Is that supposed to be RPM for peak torque?
Also, changing the bins in any of the xls files doesn't seem to alter the advance in any of the cells. What am I doing wrong?
rabiddeity
Postby automat » Thu Dec 06, 2007 7:27 pm
the files got removed?
error 404
'93 Suzuki Swift 993cc 3 cylinders with a TD04L-13T , melted piston @ 25psi with a bad fuel pump. MS2E 3.0.3 standalone
'07 Suzuki SX4 2.0L , TurbineTech turbo kit. MS2E 2.0 used as a piggyback
automat
Postby Darrow » Fri Dec 07, 2007 8:09 pm
Why does Toyota say to set the timing at 10deg at idle. (~750rpm). That doesn't seem to be what this thread is saying.
This is for a 1986 Supra 5MGE
Darrow
Postby wrenchdad » Sat Dec 08, 2007 1:18 am
That would be for the base timing without any electronic advance from the ECU.
wd
wrenchdad
Postby woh » Sun Dec 09, 2007 5:14 pm
There are two schools of thought on setting the advance during idle.
For older cars, before Emission control, the idle was often set to an ignition advance like 10deg. This required the throttle to be open a bit more than with a higher advance giving higher air flow for the same engine rpm. The vacuum advance was connected to the carburettor just upstream of the throttle. During idle there was no vacuum advance. When the throttle was cracked open the advance immediately jumped to ~25deg giving instant increase in power. From my perspective, this is the preferred setting on older cars if you can tolerate the slightly higher hydrocarbon emissions and lower fuel economy during idle. It will give a slightly better take-off from a standing start and better Acceleration enrichment from a start. This generally is also accompanied with a slightly rich (<14.7:1) mixture.
With the advent of emission requirements and fuel economy the vacuum advance was moved to the manifold and high vacuum was applied during idle. This gives the same idle speed with the throttle a bit more closed and often the mixture is very close to stoichiometric. My '74 MG is less stable with these settings than with a richer mixture.
On current cars and electronic control any combination of the above is possible. Which you choose is your choice. Best you find out what the original mfg of the engine did and use those settings as a starting point.
woh
Postby Azeton » Mon Dec 10, 2007 7:25 am
I couldt open xlm files.
but anyways. i have an m50b25 and found on bmw world these numbers
Valve Timing (IO/IC) 19°btdc/41°abdc
(EO/EC) 35°bbdc/13°atdc
What do the guys that have been doings this for a time get out of this?
Azeton
Postby automat » Sat Dec 15, 2007 1:52 pm
could someone please repost the xml file that was on the first page?
automat
Postby robiniddon » Fri Jan 04, 2008 4:13 am
On the subject of why 3,000RPM is seen as the limit of advance:
Denser mixtures burn quicker than sparse mixtures.
Ignoring forced induction for a moment, when running wide open throttle (MAP ~100kpa) you'll have a dense mixture; when running closed throttle (MAP 20-50kpa) you'll have a sparse mixture.
For a given engine and a given mixture density it takes nearly a fixed amount of time to burn that mixture and thus reach peak pressure in the cylinder - this time is independent of RPM. So at low RPM you need to ignite near TDC (low RPM = less advance) and at high RPM you need to ignite further away from TDC (high RPM = more advance). The goal is to get peak pressure ~20 ATDC (as far as I understand it, anyway!).
In the old days, vacuum advance was there to advance timing for sparse mixture (low MAP = more advance) but return to mechanical timing for dense mixture (high MAP = less advance). Today we use the MAF or MAP sensor to infer density.
Old distributor based engines had all timing in by 3,500 RPM or sooner. I cannot say why that is - I have never seen it adequately explained.
I suspect it is as much an artifact of the limits of the mechanical advance systems as it is tuned to the needs of the engine. I suspect that a mechanism that would give all the advance required for peak power at 7,000RPM would have too much in mid range (say 3,000-4,000) and so would knock; rather than have a two-tiered mechanical advance, the designers settled for all in before peak torque. Remember that most mechanical distributor systems probably were push rod engines running no more than 5,500 RPM (barring the real racing stuff).
All the ignition maps that I have seen for electronic ignition on normally aspirated engines that do not have knock control continue to feed in more advance all the way to the red line, though typically the map has an anomaly on the way where timing is retarded compared to neighbouring sites. This probably corresponds to where the mechanical advance limit would have been set for that engine, had it been distributor based.
So, I think that you should aim to make your ignition map taper up from idle to max load/max rpm, rather than flat above 3,000RPM.
I hope that makes some sense!
Cheers,
Robin
robiniddon
Postby q4_fre » Mon Feb 11, 2008 2:50 am
I have not tried this, but it looks to be a reasonable good guide for turbocharged engines on ignition tuning..
Any comments? What do you think about it?
http://powerpage.dk/tuning_ignition-fil ... p_v106.xls
q4_fre
Postby offtrack » Mon Feb 25, 2008 5:14 pm
q4-fre may God bless you always, for posting that !
hear is one for old fashion dizzys with weighs and vacuum advance on a
MGB.
if found it in the either , out in google spider land.....
MS2V3+msextra,beta21+
DiyAutotune! < the best!
custom pnp harness done, default timings.
idles, cool, tripadation sets in, MLV soon.
2 years till retirement, then doing MS on wifes family cars. for economy $7 gallon fuel.
offtrack
Postby woh » Sat Apr 26, 2008 9:44 am
Here is an update of the MGB Excel file that lets you save the table as a .vex file so you can load it directly into MegaTune.
http://home.comcast.net/~whaussmann/MS_ ... on_map.xls
woh
Postby kritip » Sun Apr 27, 2008 3:31 pm
I'm going to link up my knock sensor to my pc tomo, to record, but i think i'm getting pinking, even though my maximum advance is about 20 degrees
:shock:
What does pinking/pinging sound like. Sounds like a rattly bearing to me, is that right?
Kristian
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
kritip
Re: Setting up an initial ignition timing table
Postby milesinfront » Sat May 10, 2008 9:54 pm
kritip wrote:What does pinking/pinging sound like. Sounds like a rattly bearing to me, is that right?
It varies from engine 2 engine, but yes, it's usually like small metallic rattly sounds.
Here's the XLS files that disappeared:- http://amiles.com.au/IgnitionTimingEstimator_Modded.xls
I'm not the author, so don't take any credit/liability...
-1988 325is BMW M52B28 - > MS2 Extra n Spark (60-2 Wheel, Wasted COP, Single VANOS)
-2004 Opel Corsa C / Holden Barina Z18XE - > MS1 Extra n Spark (60-2 Wheel, Wasted COP)
-1976 Triumph Dolomite Sprint Race Car -> MS1 n 'EDIS'd
-1984 C1 2.3 Alpina -> MS2 Extra n Spark (60-2 Wheel)
milesinfront
Postby automat » Thu May 15, 2008 7:16 am
ah finally the file is back :D
thank you very much!!!
automat
Re:
Postby reamon308 » Wed Jan 07, 2009 3:21 pm
86LG4T56 wrote:What I don't understand from the original post is if I am running an estimated timing max of 37 (chevy 355 w/ vortec heads, no boost), shouldn't I enter that at 20kpa/6000rpm, and subtract down to the 100kpa line?
Even stranger is this stock LT1 ignition table I planned on using. It's not linear at all:
Hi I have just been reading this thread and it is just what I have been wondering why all the Ign maps I have seen so far and I am a newby to MS I have had 30 years experience building and servicing engines including Ferrari and what I have come to realise with Ign timing is it is not so much what revs you are at as how good your cycl mix is so forget linear timing curves as yes they do look very nice and orderly, but if you could analisze the mixture for every powerstroke then I am certain it would be all over the place which is what the advance curve should be, and yes I was trained as a mechanic to never let any engine see more than 34 degrees TOTAL advance, but you live and learn that nothing is set in stone and start to question, so now I am not surprised if an engine can and needs over 50 degrees for several hundred revs before dropping back to more normal and of course this can happen several hundred times between idle and max revs so your lovely linear curve from idle to max revs is like some kid has scribbled all over your Graph, so it is all down to how good you can fill your cycls and how fast your fill can burn, so how can we achieve this with MS or is it possible, please someone let me know as I am sure we will not be able to get the max from our engines till we do ??, Regards Reamon
reamon308
Postby haddixracing » Wed Jan 14, 2009 4:07 pm
I found factory testing documentation on my Mercedes M120 V12 engine and it gives the following timing points. Just in case these are helpful to anyone out there.
Idle
Idle Speed 600-750 rpm
Idle Timing 5-15* BTDC
Idle Injector PW 2.8-3.2ms
Idle Map 58-63 kpa
Peak Torque
WOT at 3800 / 4000 rpm
WOT Timing 18-22* BTDC
Injector PW 12-17 ms
WOT Map 100kpa
1995 Mercedes S600 Coupe V12 running MSnSExtra V3.0 with Dual Dizzy and VVT control
My success story. http://www.msruns.com/viewtopic.php?f=106&t=22713
haddixracing
Postby milesinfront » Wed Jan 14, 2009 4:52 pm
5-15 @ idle? That doesn't really narrow it down much... Perhaps it uses variable timing to help control idle speed???
milesinfront
Postby haddixracing » Thu Jan 15, 2009 7:14 pm
Yeah, I imagine it bumps the idle timing up when the idle drops below a certain rpm to keep it in range. It doesn't use an IAC valve to control idle so that would make sense.
haddixracing
Postby joeyg1973 » Tue Oct 06, 2009 6:30 pm
I read this whole thing and my brain is smoking. I am a newbie and that xls sheet, no matter how much I read posts on this makes no sense. I have a toyota 2f motor that stock has a redline of 4000 and is supposed to have a timing of 7 degrees at 650 rpm. I have had the whole thing balanced as the bottom end of these engines are often out by GRAMS and mine was. I should be able to redline up to 5000 with max torque around 1800 and hp around 3600. I have no clue why this xls wants to give me ~26 degrees at idle.
Please, someone explain this to me.
Joe
joeyg1973
Postby teslo » Fri Aug 13, 2010 9:45 am
Hi guys, any update on Excel file( or OpenOffice)? Especially for rover v8 ;)
teslo
PreviousNext
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
