Ben wrote:Knowing the aquamist valve frequency isn't as relevant as knowing what frequency the pulsed WI output is set to. Maybe someone with an O-Scope and a STIM would be so kind as to test?
richyvrlimited wrote:Ben wrote:Knowing the aquamist valve frequency isn't as relevant as knowing what frequency the pulsed WI output is set to. Maybe someone with an O-Scope and a STIM would be so kind as to test?
probably my lack of understanding here, but isn't the output just a close of INJ ch2?
greenv8s wrote:richyvrlimited wrote:Ben wrote:Knowing the aquamist valve frequency isn't as relevant as knowing what frequency the pulsed WI output is set to. Maybe someone with an O-Scope and a STIM would be so kind as to test?
That's my understanding, too. Have you just answered your own question?
Ben wrote:Duh. Thanks Mr Cramer. I can't believe I didn't see that coming.
Matt Cramer wrote:Close, but it's the other way around - 60 hz is 1 RPM, so you have to divide instead of multiply.
Mike_Robert wrote:Think of the "M" in "RPM" ->Minute<- Your calcs reflect "RPS" - seconds. 1 rev per second = 60 RPM, 2 rev/sec = 120 RPM, etc.
-Mike
Mike_Robert wrote:Guys, I posted the following at miataturbo.net - just FYI!Quote:
Originally Posted by cmtech1 View Post
Our Valve has a nice advantage as can be both positional or on time/ off time. Positionary will give you far better results. Using on/off you will have a hard time to get rid of pulsing. When using positionary you will get a nice steady pulse free stream. If you wish to do an on/off style setup, by all means this valve can do it. Its very fast.
As a side note, Vari-cool has the ability to hook up to your computer, you can set the MIN dutycycle (as well as max and the curve). If you have a large nozzle, we recommend to move the dutycycle from 25% to 32% for the very reason you suggest.
The frequency range of the soleniod is 300 to 15,000 HZ.
CM
CM, thanks for your interest in expanding to the MS platform. I've been involved with the MS project for quite some time and have a decent working knowledge of the hardware, firmware, limitations, etc. Can you detail precisely what the HSV requires regarding logic/power to operate in the positionary mode? Is it directly frequency controlled, in that a higher freq causes a greater flow? Or is it duty cycle controlled at a static freq in the 300-15K range? The first case can be handled by either of the MS injector channels driving a multiplier chip, the DC case could be handled by use of one of the other outputs and some relatively easy firmware changes.
Thanks,
-Mike
Users browsing this forum: bbbrad and 1 guest
