Moderator: djandruczyk
Cuz wrote:sure - email addy?
Cuz wrote:no worries. Do you mind having a look into the potential Boost Tables I posted in this forum?
superchargingmachine wrote:I'm not sure this is the right place to post this question but it is related to dashboards so it seems close. When I click the button to load a dashboard and select any.xml dash MegaTunix closes. Is this normal when I'm not connected to the ECU?
I'm new to Megatunix but followed the setup and update instructions, which loaded all the latest ecu configs up to 3.2.4 so I thought I had things working properly.
superchargingmachine wrote:Completely uninstalled Megatunix, updated everything including the support files and installed from a fresh git compile. This time Megatunix only shows up is Accessories Menu. However, I'm still having the same problem on selecting, General, Choose a Dashboard File Megatunix closes.
sudo make uninstall
sudo apt-get purge megatunix
sudo rm -rf /usr/local/share/MegaTunix /usr/share/MegaTunix
sudo make install
sudo ldconfig
superchargingmachine wrote:I decided to try again tonight with a clean install. I ran Megatunix from a terminal window. The gc-friendly is NOT set occurs after selecting the ECU and clicking the load button. Everything else happens after selecting General, choose a dashboard, open. Is this helpful in figuring out what's wrong? Thanks in advance.
choose_file
parent 0x8554678
on_top TRUE
filter *.*,All Files,*.xml,XML Files
filename (null)
default_filename (null)
default_extension (null)
absolute_path (null)
default_path Dashboards
external_path (null)
shortcut_folders Dashboards
project (null)
title Select Dashboard to Open
ACTION_OPEN before gtk_file_chooser_dialog_new
after gtk_file_chooser_dialog_new
should be using system path + Dashboards
initiating dialog to run
it returned
GLib (gthread-posix.c): Unexpected error from C library during 'pthread_setspecific': Invalid argument. Aborting.
Aborted
