linuxman51 wrote:Nothing appears to burn, nothing smells funny, and nothing gets hot.
racingmini_mtl wrote:As mentioned on the V1.1 section on the web page, the board has 6 pads with the 5th pad being a ground (which was not there on the V1.0) and the 6th pad being the 5V supply (as you assumed). The 5th pad is for the low current ground (associated with the 5V supply) which is used to power the LM1949 chips. This has to be connected to the ground on the MS board and if it is not present you will not have a functional board.
I definitely need to update the web page to reflect this because I agree that it can be confusing with just a small note in writing instead of the picture showing the connections. I apologize for any problem this has caused.
If that was not your problem let me know and we'll work this out.
