by LT401Vette » Fri Jul 11, 2008 9:50 am
You have 2 types of errors there.
"The failed to subscribe to Outputchannel XXX" are caused by your dashboard. It appears you have a dashboard for a different firmware loaded. I have made this error a little more clear and dashboards are filtered to ones supported for your current config in the newer releases. If you are on .951 or newer, try right clicking and on the menu:
File --> Load Dashboard
The drop down will be filtered to supported dashboards.
Alternatively you can put the dash in designer mode and go through each of the gauges that have an invalid OutputChannel set and change it to the one that is valid for your firmware by right clicking on the gauge:
Properties --> OutputChannel
or
Predefined gaugesX --. What ever gauge you what it to be.
The other errors:
std_XXXXXX not found in current configuration
That is because those are dialogs that are not defined in the ini files, they are fixed dialogs that MegaTune has built in and they just aren't there yet in TSMS.
0.96 will be out tonight(hopefully) and includes warm_up enrich. Accesl enrichment will be in the next release.
Then we should be down to just the MSII WB, Temp Sensor and generic ports.
Once those missing dialogs are done, it will be moved to beta.
