The readings seem opposite of each other, that when one reads lean, the other reads rich.
I set up the LC1 meter according to the specs sheet, MS seems to run the car well enough, but its not in synch.
Any ideas guys?
LC1 meter and megatune
1981 VW Scirocco w 2L 16v
Re: LC1 meter and megatune
MS1 or MS2?
There are 3 places you have to setup the LC1
- in the LM programmer
- In the configurator for the project you are using
- In the megatune calibration tool in the 'tools' menu (only if you're using MS2)
scirocco ;)
scirocco ;)
