OBSOLETE 0.9.18 released, post bugs here...
Moderator: djandruczyk
- MS/Extra Guru
avail via sourceforge, see links below in my signature...
Enjoy. post bugs to this thread please..
Reason: locking thread
David J. Andruczyk
Re: 0.9.18 released, post bugs here...
Hey. MTX crashes for me when I try use offline mode.
Is this a bug or is it my fault?
Thanks for all the time you put into this. It's great software.
Code: Select all
$ megatunix -rsd
debug option "1"
version option "0"
quiet option "0"
no rttext option "1"
no status option "1"
no maingui option "0"
autolog_dump "0"
autolog_minutes "5"
autolog_dump_dir "(null)"
autolog_basename "(null)"
(megatunix:4475): libglade-WARNING **: could not find signal handler 'notebook_page_changed'.
AE86 + 4age + MS2
- MS/Extra Guru
Did you do the typical, ./configure ; make ; sudo make install in the megatunix-0.9.18 dir? (it won't run unless it's installed as it can't find it's config files....)johntramp wrote:Hey. MTX crashes for me when I try use offline mode.
Is this a bug or is it my faultCode: Select all
$ megatunix -rsd debug option "1" version option "0" quiet option "0" no rttext option "1" no status option "1" no maingui option "0" autolog_dump "0" autolog_minutes "5" autolog_dump_dir "(null)" autolog_basename "(null)" (megatunix:4475): libglade-WARNING **: could not find signal handler 'notebook_page_changed'.
Hard to say, what OS, and how far along did you get in the GUI before it crashed? If you got to firmware selection, which one did you pick?
David J. Andruczyk
Hey. I figured it out, was a stoopid mistake of mine.
Sorry
Sorry
AE86 + 4age + MS2
- MS/Extra Guru
What was the mistake if I may ask? It would be helpful to know what you did wrong, so I cna find a way to make the build or install procedure this more clear to others who might make the same error.johntramp wrote:Hey. I figured it out, was a stoopid mistake of mine.
Sorry
David J. Andruczyk
I had copied the 0.9.17 binary to /usr/bin/ and not updated it after the upgrade. Now I have created a symlink to /usr/local/bin instead. Is there a way to have it install to /usr/bin instead of /usr/local/bin?
The logviewer is still not working for me though - It is giving a 'Floating point exception' when I select any of the variables. I've tried it in debug mode too, but it didn't give any more info. I am running ArchLinux.
Cheers.
-John
Cheers.
-John
AE86 + 4age + MS2
- MS/Extra Guru
For the logviewer, are you using realtime mode (shows live data), or playback mode (shows from a logfile)? If from a log can you zip up the log and pm it to me?johntramp wrote:I had copied the 0.9.17 binary to /usr/bin/ and not updated it after the upgrade. Now I have created a symlink to /usr/local/bin instead. Is there a way to have it install to /usr/bin instead of /usr/local/bin?
Cheers.
-John
First thing though would be to clean out the old stuff..
Code: Select all
rm -rf /usr/local/bin/dashdesigner /usr/local/bin/gaugedesigner /usr/local/bin/megatunix /usr/local/share/MegaTunix /usr/bin/megatunix
Code: Select all
./configure --prefix=/usr ; make clean ; make ; sudo make install
David J. Andruczyk
Hi.
I have removed everything and reinstalled like you recommended, but it still crashes.
The error is in realtime mode, but in playback mode it crashes aswell, except this time I getwhen loading the logfile, then
when selecting variables. This happens as soon as I click any variable.
Cheers.
-John
Code: Select all
!! ERROR, bug detected, code to detect precision in logfiles isn't written yet!!!!
Please slap the author
Code: Select all
Cheers.
-John
AE86 + 4age + MS2
- MS/Extra Guru
Strange, i don't get the crash. What firmware does megatunix detect (see the general tab)? There's probably a bug in one of the Realtime variable map files that is specific to your firmware release.johntramp wrote:Hi.
The error is in realtime mode, but in playback mode it crashes aswell, except this time I getwhen loading the logfile, thenCode: Select all
!! ERROR, bug detected, code to detect precision in logfiles isn't written yet!!!! Please slap the author
when selecting variables. This happens as soon as I click any variable.Code: Select all
Cheers.
-John
David J. Andruczyk
I'm seeing the real time log errors with msns-extra-029y4 derived firmwares since .17 on linux. Have not confirmed this on windows. The last I successfully used realtime logs is .16.djandruczyk wrote:johntramp wrote:Hi.
I did not report yet as I wanted to confirm it was not my tweaked profile. (same files as 029yx, just different firmware revision & signature strings) Yes, I did update the maps & profiles at .18 due to the "api" change. Have learned to watch for changes on releases.
Have confirmed with box stock msns-extra-029y4 that the playback gives the "slap the author" precision error.
Trying to do it live causes a hard exit with no log entry once you select a variable.
Thanks, & have a good holiday!
Alan
I tried installing MTX on another laptop which runs Ubuntu and got the same crash, so that would also suggest the firmware.
I am running MS/Extra hr_10e.
Would you expect the latest hr code to work fine?
-John
-John
AE86 + 4age + MS2
- MS/Extra Guru
yes i would, and i test with that firmware on my dev machine. It would help if you recompiled thecode using the "--debug" flag to ./configure , i.e.johntramp wrote:I tried installing MTX on another laptop which runs Ubuntu and got the same crash, so that would also suggest the firmware.
-John
Code: Select all
./configure --enable-debug ; make clean ; make ; sudo make install
David J. Andruczyk
I just tried what you said with the playback mode. Out of GDB it didn't give any more info when it crashed in --debug mode. Here is the backtrace, but when it crashed in GDB it didn't exit the programme, it just froze the Plyback Controls window.
Here is the realtime mode. It also froze on the select variables window.
Would you like me to email my log file to you? As it's too large to attach.
Thanks for your time.
-John
Code: Select all
(gdb) run
Starting program: /usr/bin/megatunix
[Thread debugging using libthread_db enabled]
[New Thread 0xb70fb710 (LWP 18423)]
[New Thread 0xb6904b90 (LWP 18424)]
[New Thread 0xb60a3b90 (LWP 18425)]
[Thread 0xb60a3b90 (LWP 18425) exited]
Program received signal SIGFPE, Arithmetic exception.
[Switching to Thread 0xb70fb710 (LWP 18423)]
0x08087d4d in trace_update (redraw_all=1) at logviewer_gui.c:935
935 total = len < lo_width/lv_zoom ? len : lo_width/lv_zoom;
(gdb) bt
#0 0x08087d4d in trace_update (redraw_all=1) at logviewer_gui.c:935
#1 0x08085238 in lv_configure_event (widget=0x8840ec0, event=0x0, data=0x0) at logviewer_events.c:83
#2 0x080868d3 in populate_viewer () at logviewer_gui.c:380
#3 0x08086314 in view_value_set (widget=0xa3642d0, data=0x0) at logviewer_gui.c:250
#4 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0
#5 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#6 0xb76f0e5d in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0
#7 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#8 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#9 0xb7bcce1a in gtk_toggle_button_toggled () from /usr/lib/libgtk-x11-2.0.so.0
#10 0xb7bcce63 in gtk_toggle_button_clicked () from /usr/lib/libgtk-x11-2.0.so.0
#11 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0
#12 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0
#13 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#14 0xb76f0696 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0
#15 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#16 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#17 0xb7a55c7a in gtk_button_clicked () from /usr/lib/libgtk-x11-2.0.so.0
#18 0xb7bccb98 in gtk_toggle_button_released () from /usr/lib/libgtk-x11-2.0.so.0
#19 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0
#20 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0
#21 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#22 0xb76f0696 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0
#23 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#24 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#25 0xb7a55d1a in gtk_button_released () from /usr/lib/libgtk-x11-2.0.so.0
#26 0xb7a55d53 in gtk_button_button_release () from /usr/lib/libgtk-x11-2.0.so.0
#27 0xb7b093d6 in _gtk_marshal_BOOLEAN__BOXED () from /usr/lib/libgtk-x11-2.0.so.0
#28 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0
#29 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#30 0xb76f0ae5 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0
#31 0xb76f21eb in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#32 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#33 0xb7c1df8e in gtk_widget_event_internal () from /usr/lib/libgtk-x11-2.0.so.0
#34 0xb7b01eba in gtk_propagate_event () from /usr/lib/libgtk-x11-2.0.so.0
#35 0xb7b03277 in gtk_main_do_event () from /usr/lib/libgtk-x11-2.0.so.0
#36 0xb799c00a in gdk_event_dispatch () from /usr/lib/libgdk-x11-2.0.so.0
#37 0xb7646311 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#38 0xb76499a3 in g_main_context_iterate () from /usr/lib/libglib-2.0.so.0
#39 0xb7649ec2 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#40 0xb7b03759 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#41 0x0808ad0d in main (argc=1, argv=0xbff5ba74) at main.c:115
Code: Select all
(gdb) run
(gdb) bt
-John
AE86 + 4age + MS2
I just updated to MS/Extra hr_10g and still get the same problem.
AE86 + 4age + MS2
- MS/Extra Guru
Please run it again till it fails (under GDB). this time run the following commands:johntramp wrote:I just tried what you said with the playback mode. Out of GDB it didn't give any more info when it crashed in --debug mode. Here is the backtrace, but when it crashed in GDB it didn't exit the programme, it just froze the Plyback Controls window.
Code: Select all
(gdb) run Starting program: /usr/bin/megatunix [Thread debugging using libthread_db enabled] [New Thread 0xb70fb710 (LWP 18423)] [New Thread 0xb6904b90 (LWP 18424)] [New Thread 0xb60a3b90 (LWP 18425)] [Thread 0xb60a3b90 (LWP 18425) exited] Program received signal SIGFPE, Arithmetic exception. [Switching to Thread 0xb70fb710 (LWP 18423)] 0x08087d4d in trace_update (redraw_all=1) at logviewer_gui.c:935 935 total = len < lo_width/lv_zoom ? len : lo_width/lv_zoom; (gdb) bt #0 0x08087d4d in trace_update (redraw_all=1) at logviewer_gui.c:935 #1 0x08085238 in lv_configure_event (widget=0x8840ec0, event=0x0, data=0x0) at logviewer_events.c:83 #2 0x080868d3 in populate_viewer () at logviewer_gui.c:380 #3 0x08086314 in view_value_set (widget=0xa3642d0, data=0x0) at logviewer_gui.c:250 #4 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0 #5 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #6 0xb76f0e5d in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0 #7 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #8 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #9 0xb7bcce1a in gtk_toggle_button_toggled () from /usr/lib/libgtk-x11-2.0.so.0 #10 0xb7bcce63 in gtk_toggle_button_clicked () from /usr/lib/libgtk-x11-2.0.so.0 #11 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0 #12 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0 #13 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #14 0xb76f0696 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0 #15 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #16 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #17 0xb7a55c7a in gtk_button_clicked () from /usr/lib/libgtk-x11-2.0.so.0 #18 0xb7bccb98 in gtk_toggle_button_released () from /usr/lib/libgtk-x11-2.0.so.0 #19 0xb76ea264 in g_cclosure_marshal_VOID__VOID () from /usr/lib/libgobject-2.0.so.0 #20 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0 #21 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #22 0xb76f0696 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0 #23 0xb76f2374 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #24 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #25 0xb7a55d1a in gtk_button_released () from /usr/lib/libgtk-x11-2.0.so.0 #26 0xb7a55d53 in gtk_button_button_release () from /usr/lib/libgtk-x11-2.0.so.0 #27 0xb7b093d6 in _gtk_marshal_BOOLEAN__BOXED () from /usr/lib/libgtk-x11-2.0.so.0 #28 0xb76db359 in g_type_class_meta_marshal () from /usr/lib/libgobject-2.0.so.0 #29 0xb76dcbe3 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #30 0xb76f0ae5 in signal_emit_unlocked_R () from /usr/lib/libgobject-2.0.so.0 #31 0xb76f21eb in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #32 0xb76f27d6 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #33 0xb7c1df8e in gtk_widget_event_internal () from /usr/lib/libgtk-x11-2.0.so.0 #34 0xb7b01eba in gtk_propagate_event () from /usr/lib/libgtk-x11-2.0.so.0 #35 0xb7b03277 in gtk_main_do_event () from /usr/lib/libgtk-x11-2.0.so.0 #36 0xb799c00a in gdk_event_dispatch () from /usr/lib/libgdk-x11-2.0.so.0 #37 0xb7646311 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0 #38 0xb76499a3 in g_main_context_iterate () from /usr/lib/libglib-2.0.so.0 #39 0xb7649ec2 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0 #40 0xb7b03759 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0 #41 0x0808ad0d in main (argc=1, argv=0xbff5ba74) at main.c:115
Thanks for your time.Code: Select all
-John
print len
print lo_width
print lv_zoom
print total
Odds are one of those comes back as a zero and it causes the fault. Strange though that i don't get the same issue.
David J. Andruczyk
- MS/Extra Guru
nevermind, i found the issue. i fixed the problem in CVS. it turned out the lv_zoom param got initialized to zero which causes a divide by zero (floating point exception). A temporary fix is to close megatunix and edit ~/.MegaTunix/config with a text editor, find the [Logviewer] section and change "zoom" to 1. I also suggest setting the scroll_delay to 100 as well (safe defaults).
David J. Andruczyk
- MS/Extra Guru
List of bugs fixed and new features completed for .19
Text entry handling for temperatue sensitive controls would fail to accept typed in input. Status: Fixed
Logviewer crash. Status: Fixed
numerous small crashes fixed
New features:
- MS2 Table editor (new GTK+ custom plotter widget, full AA, drag and drop graph editing)
- TCP/IP Socket (partially complete) use to the point where you can manipulate values via telnet, or via a client script.
- MS2-Extra Tooth Trigger Monitor 2/3rd implemented. (Tooth, Trigger, but not yet composite. If someone can make sense of jsmcorinta's docs on the composite logger, and decipher them to "idiot engineer" level and then explain then to me, it would be much appreciated.
- All tabs that had radio buttons now use comboboxentries (dropdown boxes) which makes many of the tabs smaller and easier to follow.
- CLI and GUI firmware loading tools (msloader, mtxloader), works for ALL firmwares, whether MS1 variants or MS2 variants
New features:
David J. Andruczyk
Dave
I use a USB-RS-232 adaptor cable on my XP PC but megatunix v18 only seems to consider com ports up to 3. My com port is 5: com5. When I type com5 into the communications page nothing happens? What should I do?
PS: You are going to have to be patient with me. This is my first real MTx experience and I WANT it to work! Once I've got it working I'm going to be bugging you to get my "AFRerror" gauges working but for now I just want to get things working.
Kind regards
Philip
Philip
- MS/Extra Guru
Philip Lochner wrote:Dave
OK, I found a bug related to that, so you can't use the gui to get around it (it causes a crash in some cases) and tends to ignore the suggested serial port in 0.9.18.
So, close megatunix, open up C:\program files\megatunix\.megatunix\config and look for the "[Serial]" section.
It should look something like this:
Code: Select all
[Serial]
autodetect_port=TRUE
potential_ports=COM1,COM2,COM3,COM4
baudrate=9600
read_wait=40
port_name=COM1
you can also change "port_name=COM1" to "port_name=COM5"
David J. Andruczyk
