lost sync v3.57
spyro
lost sync v3.57
Post by spyro »
i have a megasquirt v3.0 thats was working ok but i bought a new one v3.57 to replace the 3.0
vr sensor / 60-2
now im getting lost sync above 3000rpm i have tried to tune the pots , tried to reverse polarity but the problem stays the same
why does it work ok on the 3.0 and not on the 3.57 ?
Re: lost sync v3.37
That is strange. Difficult to tell what is going on without an oscilloscope.
Have you used the "lost sync" composite logger to see what tooth pattern you are getting when it loses sync?
prof315
Re: lost sync v3.37
Post by prof315 »
spyro wrote:i have a megasquirt v3.0 thats was working ok but i bought a new one v3.57 to replace the 3.0
vr sensor / 60-2
I have had the same problem with MS2/Extra and a 60-2 tooth wheel. Matt Cramer hooked me up with a simple fix. Just add a 10K resistor to the signal line. I have done this on 5 MS2/extra installs that were using a 60-2 tooth trigger wheel and it fixed all of them. They were all 3.57 boards but I had the same problem with the one v3.0 board I have built. The 3.0 board install wound up with a 36-1 tooth wheel for other reasons.
Support the developers!
spyro
Re: lost sync v3.37
Post by spyro »
im going to try that today
spyro
Re: lost sync v3.37
Post by spyro »
vr sensor / 60-2
thanks i didnt had a 10k resistor, only a 15k but it solved the problem , now it revs clean to 8000, i have to test it on the road, but it seems ok
fred d.
Re: lost sync v3.57
Post by fred d. »
hi all ,I have the same probleme whit a 3.57 ms2
36-1 optical
I have 2set up exactly the same one it a v.3 and its fine and the 3.57 lost sync around 6000 and 6400 rpm
the reason is always 2
now i just try to add the 10K resistor and still exactly the same probleme same rpm and same code
what is the next step to check ?
Re: lost sync v3.57
fred d. wrote:hi all ,I have the same probleme whit a 3.57 ms2
36-1 optical
Could you please post a tooth log of it losing sync? That will shed more light on the situation.
