would like to know what type of stock trigger the above engine is using?
And does the stock trigger compatible with ms2?
Thanks!
Cheers,
Simon
Fiat 175A 2.0L 5 Cyl 20V Turbo engine
Re: Fiat 175A 2.0L 5 Cyl 20V Turbo engine
Hi Simon...
I hope this is not toooooo late...
The Fiat 175A 2.0l Turbo motor is fully compatible with MS2 as long as you don't run Full Sequential Fuel...
It has a 60-2 wheel on the crank + 1 Pip Cam Home.
so MS2 should be able to do the 5 Cyl Seq Ignition...
Cheers
Gordon
Cheers
Gordon
