How to Install MegaTunix on Ubuntu Linux (all versions)
Moderator: djandruczyk
Did this make any sense to you?
Yes, completely, worked without a problem!
16
80%
No, not at all, what the hell is linux anyways?
1
5%
Kinda, but I got lost partway through, help me!
2
10%
My kid did it and explained it all to me...
0
No votes
I didn't even bother as it looks too hard...
1
5%
Total votes: 20
cmaid
Re: How to Install MegaTunix on Ubuntu Linux (all versions)
Post by cmaid »
Could someone compile a 64-bit deb for Lucid and upload it somewhere?
Thanks in advance!
johntramp
Post by johntramp »
Hi Dave.
The error I was talking to you about the other day was because I was missing the pkg-config package.
Code: Select all
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking for unistd.h... (cached) yes
./configure: line 16009: syntax error near unexpected token `LIBXML2,libxml-2.0'
./configure: line 16009: `PKG_CHECK_MODULES(LIBXML2,libxml-2.0 )'
Cheers
-John
AE86 + 4age + MS2
djandruczyk
MS/Extra Guru
Post by djandruczyk »
johntramp wrote:Hi Dave.
Code: Select all
Cheers
-John
I added that req to the first post (pkg-config)
David J. Andruczyk
bobbarker
Post by bobbarker »
Edit
djandruczyk
MS/Extra Guru
bobbarker wrote:Last night I got
Now on the Install I get
Code: Select all
Making install in include
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
Making install in mtxmatheval
Making install in mtxcommon
Making install in widgets
Making install in msloader
Ending with
Code: Select all
Making install in menu
make[1]: *** No rule to make target `megatunix.desktop', needed by `all-am'.  Stop.
make: *** [install-recursive] Error 1
any help would be greatly appreciated.
osx10.63/xcode3.2/macports1.90
Is this with 0.9.20, or a previous version?
David J. Andruczyk
bobbarker
Post by bobbarker »
This is with 0.9.20. Tried from the tarball, then cvs update. Very new to all this, do you need to see more of the code in term to diagnose?
djandruczyk
MS/Extra Guru
bobbarker wrote:This is with 0.9.20. Tried from the tarball, then cvs update. Very new to all this, do you need to see more of the code in term to diagnose?
NOTE: CVS is deprecated. Its unusual that you get that issue.
please run the following commands and copy the output to this thread:
Code: Select all
cd megatunix-0.9.20/desktop
ls
make clean
make
ls
David J. Andruczyk
bobbarker
Post by bobbarker »
Edit
djandruczyk
MS/Extra Guru
bobbarker wrote:
Code: Select all
paul-macbook:megatunix-0.9.20 paul$ make
make  all-recursive
Making all in include
make[2]: Nothing to be done for `all'.
Code: Select all
crx.c:60: warning: ISO C forbids initialization between function pointer and ‘void *’
crx.c:61:1: warning: C++ style comments are not allowed in ISO C90
crx.c:61:1: warning: (this will be reported only once per input file)
crx.c:62: warning: ISO C forbids initialization between function pointer and ‘void *’
crx.c:63: warning: ISO C forbids initialization between function pointer and ‘void *’
crx.c:64: warning: ISO C forbids initialization between function pointer and ‘void *’
crx.c: In function ‘c_multi’:
crx.c:278: warning: ISO C forbids conversion of object pointer to function pointer type
Tried erasing and starting over, but same result. ls returned same results in original and latter install. Thanks- Paul
Just goto into the menu directory, and ONLY the menu dir and run
Code: Select all
ls
make clean
make
ls
David J. Andruczyk
bobbarker
Post by bobbarker »
Edit
djandruczyk
MS/Extra Guru
bobbarker wrote:
Code: Select all
paul-macbook:menu paul$ ls
Makefile	Makefile.am	Makefile.in	README
paul-macbook:menu paul$ make clean
test -z "*.h megatunix.desktop dashdesigner.desktop gaugedesigner.desktop mtxloader.desktop" || rm -f *.h megatunix.desktop dashdesigner.desktop gaugedesigner.desktop mtxloader.desktop
rm -rf .libs _libs
rm -f *.lo
make: *** No rule to make target `megatunix.desktop', needed by `all-am'.  Stop.
pauls-macbook:menu paul$ ls
This is what I got. Thank you for your help.
A-HA! I see my issue. I screwed up the makefile so it didn't put those files in the tarball..
I have committed a fix to the git repo. I'll reply back as soon as I get this tested on a mac.
David J. Andruczyk
bobbarker
Post by bobbarker »
Any updates on this? Tried compiling with newest release off sourceforge and using latest .git with basically same results as above.. Pm me if thats easier for you, my mac is free for testing.
djandruczyk
MS/Extra Guru
bobbarker wrote:Any updates on this? Tried compiling with newest release off sourceforge and using latest .git with basically same results as above.. Pm me if thats easier for you, my mac is free for testing.
you've tried pulling from git? When? I verified the files are present in a git checkout, so it should be working
David J. Andruczyk
piledriver
Post by piledriver »
...builds fine on my Mandriva 2010.1 and 2010.0 setup, which would lead me to think it isn't a makefile issue... (I'm not installing Ubuntu again,I suppose I do have space for a VM on the big box)
checked vs. latest git pull (worked on last one as well)
I can see missing/renamed dep issues between distros, but both are using gnu make...
bobbarker
Post by bobbarker »
For some reason I cant use git clone to compile, so I had to dl from git hub and place in dir. Attached is what I keep getting. Its user error I'm sure, maybe I should just run a windows xover. Thought I could figure this out.
piledriver
If you are running OSX, you're in totally the wrong thread... Perhaps Ubuntu is installable on Macbooks?
https://help.ubuntu.com/community/MacBook
ah... (from autogen.doc) checking dynamic linker characteristics... darwin10.4.0 dyld
You're lost. The OSX thread is here: http://www.msextra.com/forums/viewtopic ... 06&t=35592
...From reading the OSX thread, installing/dual booting Ubuntu should be a breeze (and much faster) by comparison.
Tip: to update an existing git repo (like the downloaded version) the command is "git pull" from the directory the repo is in. (ls should show configure etc)
"git clone' is likely to bork on an existing repo (refuse to do the wrong thing) I ran ino that the first time I ran git. (try "man git")
djandruczyk
MS/Extra Guru
git clone for creating a new working copy of a remote repo. git pull to pull in the latest changes from the remote repository
i.e.
really quick way:
Code: Select all
mkdir git ; cd git
git clone git://github.com/djandruczyk/MegaTunix.git
cd MegaTunix
./autogen.sh
make
sudo make install
This assumes you have all proper pre-reqs installed.
David J. Andruczyk
HMC
Post by HMC »
Hi guys,
It is not exactly Ubuntu... I have added an ebuild to Gentoo bugzilla for building from git.
http://bugs.gentoo.org/show_bug.cgi?id=102449
gtpilot
Post by gtpilot »
8.04 UBUNTU install - followed the instructions and Megtunix installed and runs but I cannot get the Gauge builder or Dash builder to run...they show up under the Automotive group in the menu but clicking on them doesn't propduce any results.
What infomation do I need to post to help troubleshoot the problem?
Intel Celeron 800MHz SBC, 1GB RAM, 8 GByte CF running UBUNTU, 12" ELO Touchscreen monitor...
Thank you in advance for your help.
Kirk
djandruczyk
MS/Extra Guru
gtpilot wrote:8.04 UBUNTU install - followed the instructions and Megtunix installed and runs but I cannot get the Gauge builder or Dash builder to run...they show up under the Automotive group in the menu but clicking on them doesn't propduce any results.
Kirk
run it from a terminal and see what messages it spits out.
David J. Andruczyk
