slow67 wrote:4. What about manual hold gear option? (if the trans is in manual 1st, it stays in manual first, and if in manual 2nd, it stays in manual 2nd, etc)?
UnaClocker wrote:slow67 wrote:4. What about manual hold gear option? (if the trans is in manual 1st, it stays in manual first, and if in manual 2nd, it stays in manual 2nd, etc)?
James is actually adding a paddle shift mode to the code as we speak. That should cover this feature pretty well. It will ONLY be in the gear you paddle shift into, nothing short of maybe a calculation to prevent a down-shift over-rev should override the paddle shifter/manual mode.
jsmcortina wrote:Manual hold should already be there. If the selector is in 2nd it won't shift up out of 2nd.
slow67 wrote:One downfall of a paddle shifter (in a higher-hp application) is the over-run clutches aren't on (if in Gear Position D4) in gears 1-3. Also no engine braking (with a stock Valvebody you have to be in Manual 1st for engine braking in 1st gear, manual 2nd for 2nd gear, etc).
With no engine braking, you could let off the gas, the engine would go to near-idle, and once you hit the gas again (assuming WOT), it could blow up the overdrive roller clutch. It is feasible to build a valve body that has engine braking in 1st-3rd if you have the shifter in D3 (Doing it in gear position D4 is more difficult, but feasible as well).
devojet wrote:Here are my comments,
1. Lance used the full table as you suggest in the megashift code for the GPIO. (see http://www.msgpio.com) I think James's implementation gives the same information but would use less memory to store the information.
4. I like the idea of a manual mode that follows the shifter input, but doesn't shift up or down ie if you select 2nd it wont shift up or down. This would be handy on a dyno when tuning the engine.
UnaClocker wrote:slow67 wrote:One downfall of a paddle shifter (in a higher-hp application) is the over-run clutches aren't on (if in Gear Position D4) in gears 1-3. Also no engine braking (with a stock Valvebody you have to be in Manual 1st for engine braking in 1st gear, manual 2nd for 2nd gear, etc).
Ahh, yeah, the Chrysler transmissions don't have that "problem" (for lack of a better word), our shifter/valve body really only selects forward/backward/neuteral, the 4 forward positions don't change anything hydraulic in the trans. So yeah, while the paddle shift is a solution for the Chrysler guys (at least this one model of Chrysler trans), I understand why it won't for the GM trans.
slow67 wrote:a few more questions....
Would it be easier hardware/codewise to just have the TCC on/off instead of PWM?
Has anyone thought of using the Map Sensor instead of TPS for load (would be much easier for retrofitting carbed vehicles)?
How is the engine coolant temp referenced in the code? Modern GMs don't really take into account ECT into any equations.
Any thoughts of adding a Trans temperature Bias table to adjust the PCS for trans fluid temp?
UnaClocker wrote:I think the TCC just ramps up slowly to be easier on the clutch. With a high stall TC, there can be quite a jolt when it engages. While it might be simpler to not have that, it's already there, so it's simpler to just leave it there. ;) heh
I'm pretty sure you can use MAP or TPS for load already.
