setting lambda delay
Re: setting lambda delay
I'm betting that the High RPM / High MAP settings are too high. Even if you have a long travel to the Lambda sensor, the High MAP especially in the High Map is still fast. It is the low RPM low MAP that get slower
you have plans for this? estimate release date?LT401Vette wrote:It would probably be god to have some sort of wizard to set the default delays.
thanks
Robert
MS3x 1.4.1 | TS 3.0.28
Phil, did this idea (table generator) get scrapped?
Sorry for the resurrection but a lambda delay wizard would be nice!
Bump
MS2 Extra V3.0 board
Yea this is needed bigtime.
Support for a wizard.
If the data is in a log, wouldn't it be best just to recommend a table based off a log?
I'm all for removing one less manual activity.
1988 Mustang, 357W Clevor, 12.5:1 pistons, 2bbl Cleveland heads, Street Boss intake converted to EFI, 30lb/hr injectors (Red Tops), MS3.57 Extra, Full Sequential Injection, 190L/hr pump, TFI, MSD 6AL, T5 transmission.
Yeah, such a wizard would be very nice!!!
fun is not a straight line
Sven
http://www.mx-5club-sachsen.de
http://miata.cardomain.com/id/svenmx5
NB-1998-1,6-Garrett T25 HGP Turbo Stage I
Sven
I'd also really like to see the delay wizard.
1995 GT Mustang
302 SBF, Trick Flow Twisted Wedge heads, Trick Flow Stage 1 cam, Edelbrock Performer intake
MS3X, Hall 36-1 crank, Hall cam, Ford slot MAF, 2x 14point7 Spartan 2 WBO2, D585 coils, 42 lb/hr Bosch fatties
Great idea on the wizard, hope this is not forgotten
+1 for the wizard
+1
Sent from my SM-N950F using Tapatalk
Another vote for a wizard
Found this thread while trying to figure out the best way to set the AFR delay... This process seems ripe for an "autotune" to set the delay..
So, +1 on this feature request!
Another vote for a delay wizard .. My setup seems particularly sensitive to the effects of an inaccurate wbo2 delay.
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Has there been any update on this tool?
Would love to be a beta tester, as it would be tons better then whatever I have.
I tried to do everything scientifically, set up a button to switch between two fuel maps and measuring on MLV, but none of the values seem to work. Held as a stable value, and measured between when the button was pressed and when the AFR reaches the first peak of the second fuel maps stable AFR to measure the transition. Numbers have been equal pressing or releasing the fuel map button, is just autotune just seems to be worse and worse.
Still hoping for a tool, even one just to test
Just checking to see if this is still a thing being worked on. My tune just seems to add fuel on one run, then take it away on the next, but I cannot narrow down the delay to make it find the right fuel autotune.
+1
Sent from my SM-N976B using Tapatalk
+1 would be great to have this , if not completely automated at least a semi auto way
