Release Announcements
Moderator: djandruczyk
- MS/Extra Guru
All releases will be announced here:
David J. Andruczyk
- MS/Extra Guru
Re: Release Announcements
MegaTunix 0.9.23 released!:
- Full support for MS2-Extra 3.0.3 firmware series (thru x)
- Full support of JimStim interactive control including automated ctrl
- Win2k support returned with hybrid dual runtime integrated installer
- Numerous bugfixes and memory leak removals
- Minor performance fixes.
- 2D display bugfixes with vertexs "freezing"
- Broke ECU's out into persona's and mtx now prompts at startup to choose
one to use. Required because ms2-e 3.x drops comms if it gets non-api
commands. . this is a precursor to further modularization to other ECU's
- Improved stability and feedback in network mode
- Removed global MTX lock allowing multiple instances
- added "-P" CLI option to specify a specific serial port to be used
which disables serial port autoscanning, when used
- Dashdesigner, Gaugedesigner and mtxloader all ported to use GtkBuilder over
glade.
NOTE: Major change for this release for windows users. The separate GTK+ runtime IS NO LONGER REQUIRED!. If you installed in previously I strongly urge you to uninstall it and reboot prior to installing this version. The MegaTunix installer includes a private hybrid runtime that is isolated, and should not interact with anything else on the system. Please start a thread if you notice any issues.
Binaries for debian lenny, and ubuntu hardy, jaunty, karmic and lucid (lucid may work on maverick, I don't have a maverick box so haven't tested there, I've heard reports the GTK+ version there is buggy).
https://sourceforge.net/projects/megatunix/files/
glade.
David J. Andruczyk
Dave:
Has there been any improvements or planned improvements to the log display part of Megatunix?
I am at a point in my project where I have the car running but I would like to be able to view and analyze the logs from my runs to see what is going on. The last time I asked about some issues I was seeing with log replays you responded by telling me you knew there were problems in this are and that this part of the app could use a re-write. If Megatunix is not able to replay log files is there any possibility of doing it with some sort of external program?
Steve
Steve
Jaguar E-Types, modified Merkur XR4Ti, Jensen-Healey
Linux = no virii or spyware, EVER
- MS/Extra Guru
MegaTunix CAN display the logs, however there may be artifacts visible during playback, and you may needto move the log position bar once after you start playback to force the display to refresh. I do have new widgets written that looks similar to megalogviewer (without cost however), though I haven't put them into full use yet in the logviewer. Lately I've been focusing on the plugin architecture, and other (non MS) ecu support. So, in summary, you CAN view and playback logs, but the interface is clunky and non optimal, BUT usually usable.StevenD57 wrote:Dave:
Steve
David J. Andruczyk
Are there any future plans to expand this to MS3?
1992 Volvo 740 Wagon - Beater Car...CAI, 16T, catback, MS3/MS3X, & HID's
1996 Eagle Talon TSi AWD - Daily Driver...RAI, Big 16g, 3" TBE, HID's, etc.
I have several logs recorded now but whenever I try to play them back all I get is a black screen. I have tried moving the log position bar but that seems to do nothing. Is there a particular version of Megatunix I should be running to view the logs?djandruczyk wrote:
- MS/Extra Guru
If you're on linux, I encourage you to try a developmental version (via git branch modular_0.4)StevenD57 wrote:I have several logs recorded now but whenever I try to play them back all I get is a black screen. I have tried moving the log position bar but that seems to do nothing. Is there a particular version of Megatunix I should be running to view the logs?djandruczyk wrote:
You didn't mention what version you currently use.
David J. Andruczyk
- MS/Extra Guru
Yes. A very generous user donated a MS-3/MS3x to me for development purposes, since the cost of it was beyond my current means, which should hopefully arrive in the next few days, once it gets here, development and testing against it will commence.VolvoGuy50 wrote:Are there any future plans to expand this to MS3?
David J. Andruczyk
Advance notice - we are hoping to change the low-level communications method during 1.1 development - as we've briefly discussed before.djandruczyk wrote: A very generous user donated a MS-3/MS3x to me for development purposes, since the cost of it was beyond my current means, which should hopefully arrive in the next few days, once it gets here, development and testing against it will commence.
The actual tuning data exchanged will be mostly the same save additions and evolution.
1.0 release will stay as it is.
- MS/Extra Guru
urls/links to the new protocol and/or a comparison of old vs new would be strongly appreciated.jsmcortina wrote:Advance notice - we are hoping to change the low-level communications method during 1.1 development - as we've briefly discussed before.djandruczyk wrote: A very generous user donated a MS-3/MS3x to me for development purposes, since the cost of it was beyond my current means, which should hopefully arrive in the next few days, once it gets here, development and testing against it will commence.
However, I'm of the opinion of a significant change in the low level communications should warrant a MAJOR number change, not a minor number change as that is a very significant change. i.e MS3-Extra 2.x with a new low level comms api, instead of 1.1). I'd see a "significant change" would be something like a packet-ized communications (with something like a header, checksum, acknowledgement and packet start.end markers, i.e. analagous to a (very) simplified version of TCP/IP)
David J. Andruczyk
As far as I'm aware nobody is working on MS3-Extra.
There's no URL as we haven't come up with anything yet. I just wanted to remind you so you weren't all upset when it changes.
I don't really get the concern about numbers myself. So what if we call it 1.1 or 1.2 or 7.8 ?
- MS/Extra Guru
To me its just good programming style. Major api change (i.e. going from MS's stock protocol to something robust, i.e. a packetized interface with proper start/stop markers, header, checksums etc) is something I'd think would warrant a major version number change, but its entirely up to you. Since, MTX now has plugins per device subset, It'll just end up being another choice in the box, so, it can be MS3-1.0 and MS3-2.x, or MS3-1.1, I don't care either way, but by making it 2.x vs 1.1, it allows the 1.0 tree to grow/evolve without ending up with 1.0.<some large number>, it can progress as 1.0, 1.1, 1.2.x and so on. To each, his own, I guess.jsmcortina wrote:As far as I'm aware nobody is working on MS3-Extra.
David J. Andruczyk
I was using 0.9.23-rc1 on OpenSuSE 11.3 but just yesterday I downloaded 0.9.24-modular_0.3djandruczyk wrote:If you're on linux, I encourage you to try a developmental version (via git branch modular_0.4)StevenD57 wrote:
I built the code but I have not tried it out yet though. So there is a separate git tree for the 4.0 code?
If so do I use a different git reference that the usual "git clone git://github.com/djandruczyk/MegaTunix.git" ???
I think the instructions have been referenced before in this "Segmentation Fault" thread.StevenD57 wrote: So there is a separate git tree for the 4.0 code?
http://www.msextra.com/forums/viewtopic ... 08#p272132
Code: Select all
cd ~/
mkdir git
cd git
cd Megatunix
git checkout modular_0.4
./autogen.sh --enable-debug
make
sudo rm -rf /usr/local/share/MegaTunix ## REMOVE the old/existing version as lots of filenames changed and we don't want cruft laying around
sudo make install
Yamaha YZF1000 MSExtra 3.1
- MS/Extra Guru
24c wrote:I think the instructions have been referenced before in this "Segmentation Fault" thread.StevenD57 wrote: So there is a separate git tree for the 4.0 code?
Code: Select all
cd ~/ mkdir git cd git git clone git://github.com/djandruczyk/MegaTunix.git cd Megatunix git checkout modular_0.4 ./autogen.sh --enable-debug make sudo rm -rf /usr/local/share/MegaTunix ## REMOVE the old/existing version as lots of filenames changed and we don't want cruft laying around sudo make install
There is no 4.0 code
In any version control system, there is usually the concept of "branches" (think of a tree), where development is isolated from the "trunk". branches have names, I'm currently working on hte modular_0.4 branch, and will shortly be merging that back to the master (trunk), and splitting off to a new branch mainly that I've accomplished my goals for the modular_0.4 branch.
David J. Andruczyk
24c wrote: I think the instructions have been referenced before in this "Segmentation Fault" thread.
Code: Select all
This did not work:
Code: Select all
[me@mysystem git]$ !2539
Initialized empty Git repository in /home/sad/MTX_VexFiles/git/MegaTunix/.git/
remote: Counting objects: 31042, done.
remote: Compressing objects: 100% (4885/4885), done.
remote: Total 31042 (delta 26575), reused 30563 (delta 26096)
Receiving objects: 100% (31042/31042), 9.78 MiB | 742 KiB/s, done.
Resolving deltas: 100% (26575/26575), done.
Checking out files: 100% (942/942), done.
[me@mysystem git]$ cd MegaTunix/
[me@mysystem MegaTunix]$ git checkout modular_0.4
error: pathspec 'modular_0.4' did not match any file(s) known to git.
- MS/Extra Guru
StevenD57 wrote:24c wrote: I think the instructions have been referenced before in this "Segmentation Fault" thread.
Code: Select all
This did not work:
Code: Select all
[me@mysystem git]$ !2539 git clone git://github.com/djandruczyk/MegaTunix.git Initialized empty Git repository in /home/sad/MTX_VexFiles/git/MegaTunix/.git/ remote: Counting objects: 31042, done. remote: Compressing objects: 100% (4885/4885), done. remote: Total 31042 (delta 26575), reused 30563 (delta 26096) Receiving objects: 100% (31042/31042), 9.78 MiB | 742 KiB/s, done. Resolving deltas: 100% (26575/26575), done. Checking out files: 100% (942/942), done. [me@mysystem git]$ cd MegaTunix/ [me@mysystem MegaTunix]$ git checkout modular_0.4 error: pathspec 'modular_0.4' did not match any file(s) known to git.
Strange it did for me:
Code: Select all
cd
mkdir t
cd t
Initialized empty Git repository in /home/dave/t/MegaTunix/.git/
Receiving objects: 100% (31042/31042), 9.78 MiB | 858 KiB/s, done.
dave@shrapnel:~/t$ cd MegaTunix/
dave@shrapnel:~/t/MegaTunix$ git checkout modular_0.4
Branch modular_0.4 set up to track remote branch modular_0.4 from origin.
Switched to a new branch 'modular_0.4'
David J. Andruczyk
Before I started this process I created a new git directory and cd'ed into it. As I quoted I did my checkout and then cd'ed into the Megatunix dir and tried the checkout modular_4.0
I just tried it again and it gave me the same error.
I will try on a completely different machine.
That is very strange. I just tried it on a different machine and it worked fine.StevenD57 wrote:Before I started this process I created a new git directory and cd'ed into it. As I quoted I did my checkout and then cd'ed into the Megatunix dir and tried the checkout modular_4.0
Same exact steps. Weird
What were your goals for the modular_4.0 or the modular_3.0 code branches? Just curious to see what might have changed.djandruczyk wrote: There is no 4.0 code
