VVT ideas and testers
y8s
Re: VVT ideas and testers
Post by y8s »
Disregard. When I tried it later in the day it worked fine. Just needed one more reboot I guess.
AbatelliCristian
Post by AbatelliCristian »
I have installed ms3+msx in s65 engine. I load firmaware alpha10 for vvt vanos.
When I select vvt PID Q3 in msx is very hot. What's the problem?
Have second problem: vvt4 not run. If select test, not run solenoid. I test the port with pwm generic and solenoid run, but in vvt test no.
Last edited by AbatelliCristian on Sun Jun 12, 2011 2:42 pm, edited 1 time in total.
An MSQ and information on your settings would give us a chance of answering your question. However, that potentially sounds like the same issue that y8s had on his install. You might want to try wiring a 1N4001 across the VVT solenoid with banded end towards 12V.
AbatelliCristian
I edit previus post with msq... and second problem...
Do you really need to run the solenoids at 1kHz ? That's a great way to boil the flyback circuit. Your MSQ has only 2 VVTs enabled, so VVT3, VVT4 aren't going to do anything.
AbatelliCristian
?? I use 75 Hz... and I setting 4 vanos No vvts...
I load ancoder bmw v10.
I visualized all vtt angle in tuner studio, but vvt 4 not run
AbatelliCristian
I load alpha 9 and vvt4 is ok. the problem is alpha 10
but i see other problem:
vvt1 exhaust
vvt2 intake
vvt3 exhaust
vvt4 intake
vvt1 and vvt3 angle is ok, but vvt2 and vvt4 angle is <> vvt2=65 vvt4=0. if vanos on vvt2=0 and vvt4=65.
exhaust run ok with pid and vvt timing table, but intake have problem
The VVT4 problem is a newly introduced simple bug.
I've fixed it for the next release. Send me your email and I'll send you test code.
AbatelliCristian
y8s
Post by y8s »
jsmcortina wrote:An MSQ and information on your settings would give us a chance of answering your question. However, that potentially sounds like the same issue that y8s had on his install. You might want to try wiring a 1N4001 across the VVT solenoid with banded end towards 12V.
Q3 getting hot was exactly the problem I had.
Curious if this issue is going to keep popping up as more people start using VVT.
AbatelliCristian
Now the new code is all ok for vvt.
with 1n4001 the q3 is ok....
Now I test timing table...
AbatelliCristian
Exhaust vvt is all ok and pid work, but intake I have problem. In gauge the angle is correct in vvt2 and vvt4, but if in timing table I chenge the value the angle not change. It change only if I set value up the max angle setting. I think in bmw the cam exhaust cranck clock, but intake crank clockwise...
AbatelliCristian
In other test I have problem to intake vvt. If I set "advanced" in more duty means, vvt input is ok, but the table timing not work because the shaft cranking opposite. I have try set "retard" in more duty means, but I have vvt2-vvt4 error... not sinc....
In the exhaust vvt is all ok. No sinc error and the table timing work well.
AbatelliCristian
In other test I have problem to intake vvt. If I set "advanced" in more duty means, vvt input is ok, but the table timing not work because the shaft cam rotate opposite. I have try set "retard" in more duty means, but I have vvt2-vvt4 error... not sinc....
Can you post your matching MSQ and datalogs for these two settings and I'll have a look.
Have you enabled and do you see the "VVT error" indicators light up ?
AbatelliCristian
Yes, I see the vvt error indicators light up, and I see the angle gauge crazy. This if I set intake retard, but if set advanced is ok, but same times have not sinc at start up and if sinc is ok the table timing not work.
Now I have only datalog for one setting.
On the two channels you are having problems with have you tried setting the min/max angles both to zero and see what range of reported angles you get with the altered direction setting?
AbatelliCristian
Yes, I have tried to setting min/max=0 , but when I have altered direction vvt not sync and I don't see the angle cam because the gauge is crazy and I see the vvt error indicators light up....
VVT error isn't checked for when min/max are set to zero.
The direction should have no impact on the angle detection - only on the output duty.
prof315
Post by prof315 »
Time for another update/progress report on my attempt at (mis)using the very primitive VVT system on a VW 1.8T. I've got the PID dialed in pretty well and I'm staying within a 2 degrees or so of my target. The car definately likes what I'm doing. I don't have power and torque curves but rather plateaus that last 1500 (peak HP) and 3000(peak torque) rpms. Evenually I'll find a spare VVT solenoid/chain tensioner assembly to take apart and play with, then maybe I will be able to hit the target a little closer. This is using the alpha 10a code.
Support the developers!
