My current RB20DET is on it's last legs but is still running so it should make a good test case. If I kill the engine in testing there won't be any tears, better this than the expensive forged one. I used to run a MS2 doing fuel only based on the one input from the CAS which worked perfectly.
The manual currently says
What is involved in determining the phasing?Cylinder phasing unknown and likely incorrect (easy fix).
Awaiting testing on an engine
Is it just a case of determining if the firing order is correct and that the advance shown in MS is correct at the engine?
Happy to help in any way I can. I'd really like to see MS make a name for itself in the Skyline/Nissan community, I was planning on writing up my full install so other's can repeat the process.
-Matt
