juansh2385 wrote:Can I test the code with a 420a ? I am having trouble with a miss fire and i have run out or ideas maybe this can help?
jsmcortina wrote:That misfire is exactly the kind of symptoms you might get.
jsmcortina wrote:I've replicated your problem on the bench. It is due to EGO. We'll have a look soon and will get you a new test code.
Greg G wrote:Ken said the code he sent me with the PID changes had this code as well. FWIW- my car wouldn't start when I flashed it
jsmcortina wrote:Greg G wrote:Ken said the code he sent me with the PID changes had this code as well. FWIW- my car wouldn't start when I flashed it
That's because it gives a config error - you need to fix that.
You have spark B (PM4/D16) set to come full on > 80degC. Surely that will melt the coil?
Greg G wrote:Oh that! PM4 (ALED) is wired to my auxiliary fan
Whew
jsmcortina wrote:Seems Jean and I have missed something here... spark B is PM4 on MS2, but NOT on Microsquirt.
Did Ken send you a Microsquirt compiled s19 ? i.e. ms2_extra_us.s19
IG1 - Logic level spark output 1.
IG2 - Logic level spark output 2.
WLD - Warm up LED output, which can be used as the 3rd spark output or as a relay control.
ALD - Acceleration LED, which can be used as the 4th spark output or as a relay control.
