New serial protocol / MS3 pre1.1 alpha codes 12+
Re: New serial protocol
Postby jsmcortina » Tue Jul 19, 2011 9:59 am
Even more strange. That suggests that something broke during the "new serial" changes, but they were supposed to be serial changes only.
I almost wonder if your settings aren't getting through correctly ?
Postby prof315 » Tue Jul 19, 2011 11:37 am
jsmcortina wrote:Even more strange. That suggests that something broke during the "new serial" changes, but they were supposed to be serial changes only.
It that is the case it's not showing up in TS. I did a line by line check of my msq while connected to the ECU and everything was as it should be.
Jeff
The Professor
92 Corrado 2.0L ABA on MS3Pro. Support the developers! Sandy Linfert 11/4/91- 5/13/13
prof315
Postby UnaClocker » Tue Jul 19, 2011 7:24 pm
I just got a chance to load up the pre-12 test code you emailed me. I can confirm the findings. Idle stepper is happily ticking away again. TS is back to constantly dropping the connection if the ignition is on without the engine running. I don't think I ran into that problem with the new serial.
As for the idle problem.. I was thinking that it's something about the way the interrupt for the new serial is being called, it's displacing the interrupt for the idle control routine, somehow.. Or maybe you're poking into a memory location that the idle control uses with your new serial routine? Either way, glad we could help narrow this minor glitch down. I look forward to using the new serial routines full time. :)
UnaClocker
Postby LT401Vette » Tue Jul 19, 2011 7:29 pm
Please elaborate. Going offline with key on ignition off? Is there any reason you know of or is this an issue?
Postby UnaClocker » Tue Jul 19, 2011 7:34 pm
Key on, which makes the ignition on. Engine not running. TS will connect, stay connected for about 10-15 seconds, then drop the connection and go offline for a few seconds, comes back, does it again, two or three times later I get an error message and it stays offline till I close and re-open TS.
Like I said, this car and computer are a great candidate for the new serial code, I've always had issues with it staying connected. I've seen other people report this issue in the past, it's a bug that I've had for a long long time. I could shoot some video of it happening..
UnaClocker
Postby prof315 » Wed Jul 20, 2011 2:59 am
UnaClocker wrote:Key on, which makes the ignition on. Engine not running. TS will connect, stay connected for about 10-15 seconds, then drop the connection and go offline for a few seconds, comes back, does it again, two or three times later I get an error message and it stays offline till I close and re-open TS.
I get a good bit of the same at times. It was definately there (and somewhat annoying) while I was (trying) to load my msq after the firmware change. It took like 3 tries for the msq to finally load properly.
The Professor
prof315
Postby elaw » Wed Jul 20, 2011 4:18 am
Guys,
The TS thing I don't think is an alpha firmware issue! I've experienced the same thing.
I've been using the latest beta TS on my laptop doing tuning/testing in the car for several days with no problem. That's with a USB-serial dongle that I think has a Prolific chip in it.
Last night I fired up a bench-test setup I have to troubleshoot SD logging. That setup uses the USB port on the MS3 daughterboard (FTDI chip). I experienced the exact same symptoms that UnaClocker describes. Thinking it was the MS3 firmware, I flashed it to alpha 11 and then to the 1.0.2 release firmware but the issue persisted. I finally installed the release version of TunerStudio (1.004) on the laptop and the problem vanished. I reflashed the MS3 to alpha 11 and still no problem. So I think it's an issue with the 1.074 version of TS.
Eric Law
1990 Audi 80 Quattro: happily running on MS3
1997 Saab 9000 Aero: self-tweaked stock engine management
1986 Audi 4000 Quattro: R.I.P.
elaw
Postby LT401Vette » Wed Jul 20, 2011 5:32 am
It sounds like what your guys are talking about is different from UnaClocker. His issue is only happening when it the key is on but the engine is off and he is doing nothing else. After about 5 seconds he gets this message:
Warning!!
Communication Established!
However, there is a configuration error with your firmware.
As I understand it, this is happening with either the released TunerStudio or 1.074, but not with the new serial.
Now if you are getting an error message new to 1.074 and against released firmware, please go ahead and open a new report in the TunerStudio forum describing what actions cause it. It is not a known issue.
Postby prof315 » Wed Jul 20, 2011 6:44 am
LT401Vette wrote:It sounds like what your guys are talking about is different from UnaClocker. His issue is only happening when it the key is on but the engine is off and he is doing nothing else. After about 5 seconds he gets this message:
Warning!!
i am getting the same thing that Brian is. It doesn't happen quite as often and never happens with the engine running.
The Professor
prof315
Postby LT401Vette » Wed Jul 20, 2011 6:55 am
If it is that exact error message then it is the same error.
UnaClocker said that went away with the new Serial, but it sounds like elaw is still seeing it?
Would you be able to capture a comm debug log while it is happening? Preferably with the new serial.
Even if you have the log from when it happened, that will have some comm debug info from when the failure occurred.
Postby elaw » Wed Jul 20, 2011 7:07 am
LT401Vette wrote:If it is that exact error message then it is the same error.
I'm getting exactly what una described: online/offline repeated a few times at intervals of a few seconds then the message about the configuration error with the firmware. My bench-test setup can't simulate an engine, so it's "engine not running" by default :lol:
If nobody else has by then, I'll start a thread in the TS forum this evening after I've had time to test more and try and narrow down when this does and does not occur. I posted here mainly to point out that this doesn't just happen with the "new serial" code on the MS side.
Eric Law
elaw
Postby LT401Vette » Wed Jul 20, 2011 7:23 am
That is good if it is NOT happening with the new serial.
Postby LT401Vette » Wed Jul 20, 2011 8:50 am
For any of you that are getting that message with the old serial, try editing the mainController.ini file. Find the line (at or about line 157):
interWriteDelay = 1 ; delay between each byte written
Change the 1 to a 0
We were having issues with this a while back with higher interWriteDelay values, but when it was reduced to 1, it seemed to take care of it for all the machines we saw it happen on at the time. I didn't realize some of you are still seeing this and just gotten used to it. :(
What UnaClocker describes is that for him it happens every time his engine is off, for others it sounds more erratic. in the end it means that in some condition TunerStudio is sending data that the firmware does not respond to, likely it didn't receive the full message.
That is one of the points of the new serial, to insure this can not happen without clear knowledge of it and better visibility into what the controller got.
Postby UnaClocker » Thu Jul 21, 2011 7:47 pm
Any luck tracking down this problem, James? My commuter car is going to be at the shop getting an alignment on Saturday, and I have to work Saturday, so I'll be driving the Omni to work. It'd be a great time to try out the new serial routines, but I'd rather not give up idle control to do it.
UnaClocker
Postby jsmcortina » Fri Jul 22, 2011 12:27 pm
Nope. Aside from the test code I sent the other day I've been busy.
Postby jsmcortina » Fri Jul 22, 2011 1:48 pm
Phil R spotted a bug with knock - you need to define a window output pin to make the analogue input work. Will be fixed for the next alpha.
Postby jsmcortina » Fri Jul 22, 2011 2:13 pm
On the closed-loop idle problem - does it still do that without the laptop (i.e. serial) hooked up ? If the problem goes away with the laptop off that would certainly point to a data-clobbering type issue in the serial.
Postby jsmcortina » Fri Jul 22, 2011 3:46 pm
Pretty sure I've found it (stack overflowing onto variable space.) Will mail test code to Jeff and Brian.
Postby jsmcortina » Sat Jul 23, 2011 3:57 am
Per feedback from Una, that fixed it...
Alpha 13 now available - please do not use alpha12
http://www.msextra.com/doc/ms3/files/alpha/
Changes
Remove some debug variables to prevent stack overflow corrupting idle control.
Fix MAF stumble during burn.
ini mods for powercycle
Please see the full list above for the changes and warnings since alpha 11
Be sure to use the latest TunerStudio beta version. (Currently 1.078)
Postby UnaClocker » Sat Jul 23, 2011 5:10 am
TunerStudio 1.078 gave me a warning about "another program" altering my MSQ while it was reloading my MSQ onto the MS after the flash. I wasn't quite sure what to do other than tell it to ignore it. Must be a glitch in the latest TS. Just thought I'd give everyone that tries this a heads up, so they know what they might see. This was on an update from pre-12 to post-12.. :)
UnaClocker
PreviousNext
Return to MS3 Development
