LT401Vette wrote:HI all. i' m arriving from alpha 11 , now i have installed tuner studio 1.078 .
i have connection problem, goes of life often.
I have usb serial cable.
Have i to go to alpha 12 to solve it ?
Not necessarily. There is no reason alpha 11 should be going off line unless there is some reason in your connection. Is it going offline primarily while the engine is running? You may simply have a poorly shielded serial cable.
Alpha 12 with the new serial protocol does not fix bad serial connections, it does help insure they are detected and data is not used if corrupted.
raffa75 wrote:LT401Vette wrote:HI all. i' m arriving from alpha 11 , now i have installed tuner studio 1.078 .
I have never had problem with my cable. I have problem while the engine is running.
tomorrow i wil try vith 1.079
AbatelliCristian wrote:I have tested 1.11 beta version.
if vr not run and in ts I see "not synced" after a few second, ts goinig offline and I see a msgbox"Warning Communication Estabilished!
Users browsing this forum: quattrodaveuk and 0 guests
