racingmini_mtl wrote:It has taken me much longer to get around to finish the assembly but here it is:
(click on the picture for a larger view)
You can see the assembled board and the board besides Canadian quarter to show the size (similar in size to a US quarter). Then you have both sides of the board in the acse with the header and then with the screw terminal plugs. The 6-position side is for 12V, ground and the four 0-5V outputs that will go to the ADC inputs. The 8-position side is for the 4 EGT probes.
I will be putting up a web page shortly where it will be possible to order the boards but if you want one you can contact me directly in the mean time. Initially, the board will be available as an assembled board only or as a completely assembled cased unit with connectors. I may have kits available later but I'm a bit reluctant due to the somewhat tricky assembly.
bcrx7 wrote:Jean, I don't see the board on your site. How can I order one?
