MS3X Card dimensions.
Postby thomas505 » Thu Sep 08, 2011 3:59 pm
Hey, i'm currently designing an expansion board to sit where the MS3X card would sit, so I was wondering if anyone knew:
  • How wide the MS3X card is (or the mainboard - they should be the exact same width)
  • The offset of the DB37 connector, as I want to put a DB37 connector to fit in the premachined slot in the endplate.
Thanks, Thomas.
thomas505
Re: MS3X Card dimensions.
Postby SymTech Laboratories » Thu Sep 08, 2011 6:44 pm
The MS3X is 4.000" wide, and the distance between the bottom of the primary DB37 connector and the bottom of the MS3X DB37 connector is 1.040".
SymTech Laboratories, LLC ----- MSQ File Repository: megasquirt.symtechlabs.com
Postby thomas505 » Fri Sep 09, 2011 4:33 am
I actually need the offset of the connector relative to a side of the card - in essence where to place the DB37 connector in my PCB layout. (as the vertical distance is easy to fix by just mounting in a different slot).
Thanks, Thomas.
thomas505
Postby SymTech Laboratories » Fri Sep 09, 2011 10:55 am
thomas505 wrote:I actually need the offset of the connector relative to a side of the card - in essence where to place the DB37 connector in my PCB layout. (as the vertical distance is easy to fix by just mounting in a different slot).
Thanks, Thomas.
It's the same as the v3.0 board, about 1.415".
Postby thomas505 » Sat Sep 10, 2011 5:34 pm
Hey, so are you saying the dimension in yellow is 1.415"?
Thanks, Thomas.
thomas505
Postby SymTech Laboratories » Sat Sep 10, 2011 6:29 pm
Sorry, that comment did deserve clarification. It's 1.415" from the edge of the card to pin one.
Postby thomas505 » Sat Sep 10, 2011 6:35 pm
No worries :P Thanks for the help :D
thomas505
Return to Expansion boards
Users browsing this forum: Alfagta, mythbuster74, Reverant and 0 guests
