password protection PLEASE!!!!
Re: password protection PLEASE!!!!
chango yo se que puerto rico hay mucho ganzo que se quiere guillar de listo pero creo que se te esta pasando la mano...... Conosco casi todos los nombres de los buenos tuners en pr de mega pero apodo chango nunca lo habia escuchado,.... usas otro nombre por aca? btw tengo la solucion para lo que quieres pero tienes que convencerme de que realmente lo que haces es algo justo para tus clientes.
I obviously missed the point!kjones6039 wrote:There any number of ways, available in Windows and other programs, to protect your files. You can even encrypt them if you like. IMO, a lot easier than making it part of the software.
Just my thoughts of course...........
I clearly see the need that some of you have in this regard.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Anyone that pays a contractor for a tune with passwords/interlocks/whatever to prevent access is getting shafted.
Hi to all,
I have been around Megasquirt for quite a while now. The whole idea was open solutions and interaction. In the early days one of the moderators on the first forum answered a request for password protection about like this ( approx) " and if you can manage to implement that in Megasquirt we will spend all our best efforts and crack it "
And that is still my personal opinion on Megasquirt.
It really needs to be open source, also on the hardware. This is how it arrived at todays pretty advanced state, development by many individuals being rolled and refined over several years. The persons at the heart of it has hopefully got som money out of the PCBs and licensed vendors to make a reasonable income, they are certainly worth all of that and more.
And now, somebody wants to base his little efforts on all of the preceeding manyears of work by a dedicated group and then lock " his " results up!
Come on guys, this is not the way to go with Megasquirt.
W113
W113
If not understood , it will not work
I am one of these who want this option. Why? Because of the risk I encounter when I build an engine without protection on the tune. When I build an engine, I protect it with special paint color on screws or drilling the screw and locking them with security lead. This avoid the end user to open the engine with no reason. If there is a problem with the engine, things are much more easy with my lawyer.
I don't want to pay an engine if the customer did bad things with the engine!
This is the same with the tune.There is no way for me I can garanty an engine without protecting myself. If the customer want to have access to the tune, I never refuse to give him, but he has to sign some paper. Most of my customer don't care if it is a motec or a megasquirt. They just want a good engine well tuned. -Do you understand?
At least, I m not really asking a full locked tune, but at least a read only mode protected by password.
The copy issue is more a problem when I do chiptuning on oem ecu's than megasquirt msq related.
Well, you can "break" the connection to one pin on the DB15 connector on the ECU, so no one other than you can connect to it (because you would correct this before attempting to connect, of course).
This last year i have install some 15 odd ecus, combo between pectel and motec.
Like BenGTT they do not care what it is, once it is well tuned and works.
i do not use megasquirt on customer cars because it cant be locked, if something goes wrong in the warranty period there can be no question weather or not the computer connected to the ecu. Until ms supports this option it will be over looked but a lot of people.
Megasquirt has matured passed the initial thoughts of it, it is now a viable option for 98% of installs, attracting attention from installers not just hobby people with their own cars.
So, imagine this...
I asked you to map my car, because I don't know how.
After 1 year, I develop some skillzzzzz by learning, and discussing with friends.
I would like to change my hardware (turbo, injectors, what not).
What can I do? I can't take the initial map you have done on my ECU, with my money, and start to change it because it's locked?
So I'll have to pay for something that I will never own, and cannot change to my willing?
Sign a waiver saying it's no longer his tune and his responsibility and he then unlocks the map. Or at least that should be how it goes.HidRo wrote:What can I do? I can't take the initial map you have done on my ECU, with my money, and start to change it because it's locked?
For those worried about warranties — the easiest way would be for some kind of checksum so that you can find out if the tune has been changed?
That way the customer can do what he wants, if he wants — and you'll know about it.
Jean is completly right. You can even have access directly out of the shop with that way.
And same point of view as tpsretard2 !
On MS3, I even use the SD logger as a security feature. If the customer broke the engine by missing a gear or doing a 4 to 3 instead of a 4 to 5, I'll see it ! I am talking about race engine.
I too can see the need for this .... so why not write your own code or pay for it to be implemented so that some royalty $$ goes to those that deserve it.
From its infancy to what it is today is because of the "open source project", we've all benefited from the dynamic momentum and the collective development in this community, and many thanks to Bruce & Al for kicking it off. Password protection does not feel like it has very much of that "MS spirit" to it that we all love ! ... so what was it about MS that attracted us all to it in the first place ??
I'm sure Bruce and Al may have thought about this at times as some folk have taken the code and schematics and rolled there own little deal with intent for financial gain and still looked for support ... fair suck of the sav boy's !!
Perhaps if Bruce, Al, James, Phil, Eric and Jean and all the others not mentioned who have contributed... now if they had not shared any of their efforts with the code where would it all be at ?
The whole MS world revolves around sharing !!
Breastfed
Breastfed
You are right. But what I do believe (and if I'm wrong, please correct me) the users that want password protection really want is to not make the tune accessible to others, so they can't forward the tune to other guys, etc and not ONLY the risk of the user changing the tune and wreck the engine.racingmini_mtl wrote:Sign a waiver saying it's no longer his tune and his responsibility and he then unlocks the map. Or at least that should be how it goes.HidRo wrote:What can I do? I can't take the initial map you have done on my ECU, with my money, and start to change it because it's locked?
the password can be removed easy by flashing the firmware.
you just will not beable to back up the map.
then if something goes wrong and the person comes back to you you will know it is not your map as there is no password.
It is one argument i will not back down from, no password, no install.. simple. it is a shame though as it is a grate option and a lot more people would have it installed.
I do not see how it would take away from the diy community, the people that are looking for a system will still be there, and pro builders and tuners will start to use it also.
this will only lead to more users and more sales.
What other systems do offer this user lockout?
There are several different schemes out there.
Some ECUs completely lock you out with a single password.
Other ECUs allow a read-only mode without a password, but no changes can be made.
Others don't allow you to connect without a password, then a password for read-only and a different for read/write.
Some ECUs allow you to connect to a "virtual dash" but don't allow you to tune without a matching "tune" file (ie something like an .msq) - ie the TEC3R
Finally, another ECU I can think of allows you to lock certain parts of the configuration, so novices can't change important settings by mistake and damage their engine (think spark output, boost limit, etc).
Dimitris
Dimitris
The man behind MS Labs
The most common I use when I have to is Sybele Challenger 4/4+ and Commander44 ecu's from Skynam.
Sometime I may also use old Sodemo Ev11 or Ev10 ecu's. They have lockout protection but you also have to pay a license to use the ecu.
http://www.skynam.com
http://www.sodemo.com
One problem with implementing any password protection, at least on the MS2, is that the CPU is not configured for protecting the memory but to easily allow firmware upgrades. So anything that is implemented could be relatively easily cracked or bypassed.
Would it work if you added a simple password variable to the firmware (say a 8 digit number) then TS would look for this number if it was set to all 0's then there is no restriction's,else it would restrict or give only limited access to tables, TS would have to be the one to lock you out if the password in the controller dosent match the password you put in TS?
This would be great for tunners and if you didnt want password protection it could be changed easily by flashing to a older firmware, i could see how this would be very nice for tunners or customers who have spent a ton on tunning only to have someone to steal your tune, or liability issues with customers who jack the tune up and possibly mess their motors up then come back on you.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
That would work if the only thing that could connect to an MS were TS. But anyone wanting to bypass this could write a small program to read the tune using the information in the ini. The serial protocol is there and the source code for the firmware is public for anything else that needs to be known.
So any protection can't be done completely externally but has to have some code in the firmware.
