93white3400z wrote:I know you said you need to test all combinations for fuel consumption but if you want to see one that doesn't work, I've attached my MSQ for you to try. Gauge either stay at 0 or at a crazy high number.
kizzoalfa wrote:Than as I understand the Single letter command A is not supported. Do you have any plan that it will work in the future?
jsmcortina wrote:93white3400z wrote:I know you said you need to test all combinations for fuel consumption but if you want to see one that doesn't work, I've attached my MSQ for you to try. Gauge either stay at 0 or at a crazy high number.
You haven't set your injector size.
93white3400z wrote:jsmcortina wrote:You haven't set your injector size.
That could be a problem indeed. Didn't know the existance of those settings.
Thank you!
NArcher wrote:Can you add support to invert the tps signal? My car has drive by wire and the signal is 5v closed and 0v WOT.
jsmcortina wrote:Swap the 5V and GND wires.
