Honda 2.4L Pencil coil
prof315
Post by prof315 »
Well I finally got around to messing with a Denso pencil coil from a 2.4L Honda Accord. This one is from an 05 model, part # 099700-073. Using an MS3X spark driver set with ouput going high (inverted) I got a solid spark with from 3-5ms dwell. These should be pretty reliable coils and are good for deep valve covers. The definately fit a VW 1.8T 20V. They are 3 wire smart coils requiring 12V, engine ground, and trigger.
Support the developers!
racingmini_mtl
Re: Honda 2.4L Pencil coil
Post by racingmini_mtl »
Edit: Ignore this. I see that you're using the MS3X drivers so that means it's 5V and low current.
