vss signal
General support questions and announcements for MS3. See also www.ms3efi.com for MS3 information
vss signal
Postby 3.0 GT » Sun Dec 04, 2011 5:21 pm
can the ms3 use a 12v signal as vss? im hoping to use the abs sensor on the tranny output shaft and it uses 12v and i thought the megasquirt used 5v for vss but not completely sure.
3.0 GT
Re: vss signal
Postby jsmcortina » Sun Dec 04, 2011 5:28 pm
A number of the possible inputs are 12V safe.
Re: vss signal
Postby 3.0 GT » Sun Dec 04, 2011 6:08 pm
oh so it doesnt have to be a certain sensor type? just the right number of teeth in the settings page? that seems easy. thanks for the reply!
3.0 GT
Re: vss signal
Postby jsmcortina » Sun Dec 04, 2011 6:12 pm
It depends...
A 0-5V or 0-12V signal will be fine.
A VR sensor needs a conditioner circuit.
Re: vss signal
Postby 3.0 GT » Sun Dec 04, 2011 7:15 pm
okay, im pretty sure it a hall type sensor, and it has a power ground and signal. im not sure how many teeth it has yet but i will find that out soon. so it should be a simple thing to set up. thanks
3.0 GT
Re: vss signal
Postby quark2501 » Mon Dec 05, 2011 9:38 am
On the r154 transmission its a hall sensor 0-12v. Which input would you connect it to?? Is it okay to share this hall sensor with the abs???
SUPRA-------> The only way to fly
quark2501
Re: vss signal
Postby 3.0 GT » Mon Dec 05, 2011 11:45 am
quark2501 wrote:On the r154 transmission its a hall sensor 0-12v. Which input would you connect it to?? Is it okay to share this hall sensor with the abs???
i was thinking the nitrous in because i dont use nos and its 12 input, i dont think it would affect the abs... and ive seen other people on supramania use this sensor with other standalones and boost controllers that have speed based boost control. if not there is another sensor behind the speedometer that runs off the speedometer cable. i think its 12v as well though
3.0 GT
Re: vss signal
Postby 3.0 GT » Mon Dec 05, 2011 11:46 am
3.0 GT
Re: vss signal
Postby 3.0 GT » Mon Dec 05, 2011 11:50 am
well here is the wiring for the dash speed sensor. it looks like it is grounded on one side and the signal on the other, does that make it a vr sensor? or something else?
3.0 GT
Re: vss signal
Postby krisr » Mon Dec 05, 2011 1:41 pm
I'm using the nitrous input for vss and using a +12v signal with an autometer sensor on the side of a turbo400. Works really well!
Sydney, Australia
1971 Holden Monaro HQ
#16 heads, Tomahawk intake, 1000cfm 4bbl throttle body, Accel 300+ CDI
krisr
Re: vss signal
Postby Blue93Dakota » Tue Mar 20, 2012 2:40 pm
Would a sensor like this work? Could it be wired up without using up my Nitrous controls as I may use those later?
http://www.autometer.com/productPDF/1168.pdf
Blue93Dakota
Re: vss signal
Postby krisr » Tue Mar 20, 2012 3:05 pm
Yes, it'll work. That is what i'm using on my MS3X install (turbo 400 sensor - #5291) and its fine. I can't remember if i'm using the Nitrous pullup or not on the MS3X card, I think I am. But you'll soon know either way once you turn the sensor by hand and whether you get VSS in Tuner Studio.
Kris
Sydney, Australia
krisr
Re: vss signal
Postby Blue93Dakota » Mon Apr 02, 2012 3:54 pm
Blue93Dakota wrote:Would a sensor like this work? Could it be wired up without using up my Nitrous controls as I may use those later?
I installed it and put it on the Launch input and it works great. I have it wired for 12v.
Blue93Dakota
Return to MS3 General Support
Users browsing this forum: sahol69 and 1 guest
